FOAM FATAL ERROR: Maximum number of iterations exceeded |
May 9, 2011, 02:53 |
Tarak
Rep Power: 15 |
Hii,
I am running rhoPisoFoam for a duct using oneeqeddy LES model. After a few iterations I get the following error: --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const in file /home/44792/OpenFOAM/OpenFOAM-1.7.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 67. FOAM aborting Can someone please let me know how to tackle this? Thanks, Tarak |
July 14, 2011, 17:10 |
#2 | |
Walter Schostak
Rep Power: 15 |
Hi Tarak,
I hope that you're not still stuck on this but if you are, my guess would be to go to Quote:
Past that I don't know. I'm guessing you built your own test case, you may have accidentally done something that's causing the iteration counter to go out of control (but I have no concept of how you would do that). Hopefully you've already solved it! |
July 15, 2011, 02:03 |
Joel Lehikoinen
Rep Power: 14 |
I've always been able to solve this issue by checking my boundary and initial conditions, twiddling around with the underrelaxation coefficients etc. I'm not sure, but I think this is a convergence problem when you're solving for enthalpy. Also if you're running a compressible case, make sure you have the correct coefficients in correct units in the correct order for all the T-dependent quantities! A bogus density can crash your simulation very easily.
July 16, 2013, 08:53 |
#4 | |
Cay Myers
Rep Power: 12 |
August 28, 2013, 08:27 |
starter
Rep Power: 15 |
Hello Joel
How did you resolve it..I have the same issue with rhoPimpleFoam and have been trying to get rid of this error for the last week. Kindly respond. I shall be very grateful. Regards |
August 28, 2013, 17:50 |
Wouter van der Meer
Rep Power: 17 |
Hello All,
The same problem occured with me using compressibleTwoPhaseEulerFoam. I found that the iteration over the temperature tested for negative absolute temperatures. I will check the temperature dependencies, but my problem was not solved yet. Thanks for the advice though. Best wouter |
November 8, 2017, 09:19 |
Guillaume
Rep Power: 8 |
Did you guys find a solution to this problem? Thank you, Gui |
icoLagrangianFoam OF1.6 myNewParticleSolver | heavy_user | OpenFOAM | 23 | June 2, 2020 02:18 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Forces in OF15 | richard | OpenFOAM Running, Solving & CFD | 180 | July 9, 2018 10:54 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
