oscillating inlet
Like Tree9Likes
  • 2 Post By AMahrla
  • 1 Post By Eske
  • 2 Post By ngj
  • 4 Post By Eske
Old   May 18, 2011, 12:13
Default oscillating inlet
mo houssami
mo.houssami is on a distinguished road
I am using OpenFoam and I would like to have an Oscillating inlet or an oscillating wall so that my flow start oscillating.
any ideas ?
Thank you
mo.houssami is offline   Reply With Quote
Old   May 19, 2011, 09:15
Astrid Mahrla
AMahrla is on a distinguished road
There's oscillatingFixedValue boundary condition, that can be found in src/finiteVolume/fields/fvPatchFields/derived (valid for OpenFOAM-1.6.x).
Usage:
type oscillatingFixedValue;
refValue (8 0 0);
amplitude 2;
frequency 5;
Best,
Astrid
mo.houssami and M.W.G. like this.
AMahrla is offline   Reply With Quote
Old   May 24, 2011, 05:01
mo houssami
Thank you Astrid, just what I needed
Old   March 21, 2012, 01:33
November is on a distinguished road
Hi guys
How would you set the initial condition for p after u is set to be oscillatingfixedValue???
November is offline   Reply With Quote
Old   March 21, 2012, 08:49
mo houssami
Originally Posted by November View Post
Hi guys
I put zeroGradient .
Old   March 21, 2012, 20:20
Hi Mo,
Thank you for your reply.
I tried to put zeroGradient to 0/p at inlet. Somehow I got all p and u at all timesteps to be 0???
In my input file for boundary:
inlet type is set to be patch
and then in 0/p,
inlet type is set to be zeroGradient;
in 0/u, if i want to specify U=Umsin(2*pi*f*t),would the following be correct?
inlet
refValue uniform (0 0 0); //steady current velocity, which is 0 in my case
//offset (0 -1 0);
amplitude constant 1; //Um
frequency constant 0.5; //f
//value uniform (0 0 0); //not sure what this is for?
Could you tell me my problem, really appreciated. Also, may I know how you specified your outlet BC? Thanks a lot.
Old   March 28, 2012, 11:13
mo houssami
Hi, sorry for the late reply.
I only used this condition once last year, so I don't really remember...But I can send you a case that I run, and it was working fine, maybe it can help you out.
Good luck !
File Type: zip blockMeshDict.zip (662 Bytes, 110 views)
Old   March 28, 2012, 21:28
Hi Mo.
Thanks a lot. I will have a look at that.
Cheers,
Old   June 4, 2012, 07:07
flowris is on a distinguished road
Why is there only one amplitude in the velocity? I would expect a vector of three components, since velocity is a vector.
Personally, I need a velocity vector that varies in time as
(0.4, 0.6*sin(2*pi*t), 0.0)
i.e. x- and z-components are constant, y-component fluctuates.
Can this be done with oscillatingFixedValue?
flowris is offline   Reply With Quote
Old   January 11, 2013, 16:29
Mark Eskesen
Eske is on a distinguished road
I am trying to use oscillatingFixedValue as my velocity inlet BC, but I'm wondering what refValue means. Do anyone know that?
What if you only want to have an oscillating motion of the domain (without any current comming into the domain), do I need to put the velocity inlet BC like this in 0/u:
inlet
amplitude 1;
frequency 0.5;
Regards Eske
Eske is offline   Reply With Quote
Old   January 14, 2013, 04:02
When you say "oscillate the whole domain", I suppose you mean you want to do something like shaking a closed container. For this, check the different sloshing tank tutorials. They are for multiphase, but the same procedure goes for single phase.
Old   January 14, 2013, 05:05
Mark Eskesen
Thanks for your reply. What I want is to simulate waves, but not with waves2Foam. I want to make my domain oscillate forth and back. I tried with the oscillatingFixedValue as my velocity inlet BC, which actually oscillate my domain, but it is only working if refValue uniform (1 0 0) which means that a stream/current is coming into the domain in the x-direction. I don't want that current coming in, I only want to oscillate my water domain.
Thanks for your help, Mark
aashkanaa likes this.
Old   January 14, 2013, 05:12
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Mark,
Then the easiest for you would probably be to make your own version of oscillatingFixedValue, where you can have a (0 0 0) refValue.
Actually, if I remember correctly, then oscillatingFixedValue differs from the official releases and the 1.6-ext branch, where the user can choose the refValue in the latter.
Kind regards,
Niels
Eske and Alaska1964 like this.
ngj is offline   Reply With Quote
Old   January 16, 2013, 08:00
Mark Eskesen
Thanks for your reply Niels.
FYI I solved my problem concerning the oscillating inlet by looking in the code src/finiteVolume/fields/fvPatchFields/derived/oscillatingFixedValue and changed 1.0 + amplitude * sin(2 * Pi * frequency * t) to 0.0 + amplitude * sin(2 * Pi * frequency * t) and recompiled. This solved my problem concerning the oscillating velocity.
However have anybody got problems with the pressure by using the oscillatingFixedValue, because at all time my pressure becomes positive. What I think is, that somewhere in the code a positive body force or similar is hard coded. Somebody knows something about this?
Kind regards, Mark
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
Oscillating velocity inlet xiuying OpenFOAM Running, Solving & CFD 4 February 2, 2009 02:05
Inlet table in STAR-CD Sachin Siemens 1 March 26, 2008 10:22
Oscillating inlet??? Adam CFX 0 March 10, 2008 20:57
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
