problem due to reconstructPar?
Old   June 3, 2011, 16:16
Default problem due to reconstructPar?
doubtsincfd is on a distinguished road
SHM quality check:
Iteration 8
Moving mesh using diplacement scaling : min:0 max:1
Checking faces in error :
non-orthogonality > 65 degrees : 0
faces with face pyramid volume < 1e-20 : 0
faces with concavity > 80 degrees : 0
faces with area < 1e-13 m^2 : 0
faces with skewness > 4 (internal) or 20 (boundary) : 0
faces with interpolation weights (0..1) < 0.06 : 0
faces with volume ratio of neighbour cells < 0.025 : 0
faces with face twist < 0.05 : 0
faces with triangle twist < -0.99 : 0
faces on cells with determinant < 0.001 : 0
Successfully moved mesh
Moved mesh in = 28.71 s
checkMesh output:
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Topological cell zip-up check OK.
Face vertices OK.
Number of identical duplicate faces (baffle faces): 43
***Number of faces with non-consecutive shared points: 2396
<<Writing 4878 faces with incorrect edges to set edgeFaces
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface
block-mesh_FFMaxY 11820 12346 ok (not multiply connected)
block-mesh_FFMinY 10250 10867 ok (not multiply connected)
block-mesh_FFMinX 12100 12716 ok (not multiply connected)
block-mesh_FFMaxX 11258 11927 ok (not multiply connected)
block-mesh_FFMinZ 549 604 ok (not multiply connected)
block-mesh_FFMaxZ 576 625 ok (not multiply connected)
fibs_patch0 1062049 1042114 multiply connected surface (shared edge)
<<Writing 7054 conflicting points to set nonManifoldPoints
Checking geometry...
Domain bounding box: (3.394 2.4 -0.4078) (6.2044 5.2808 1.7)
Boundary openness (7.54504311808e-18 -6.14836063448e-16 -2.51663696261e-17) OK.
Max cell openness = 3.20485835477e-16 OK.
Max aspect ratio = 16.8436403273 OK.
Minumum face area = 1.04855846554e-06. Maximum face area = 0.0562236134114. Face area magnitudes OK.
Min volume = 6.37886579129e-08. Max volume = 0.0131489259567. Total volume = 16.4437716942. Cell volumes OK.
Mesh non-orthogonality Max: 64.9937164346 average: 10.5754013845
Non-orthogonality check OK.
Face pyramids OK.
***Max skewness = 14.5126753746, 1779 highly skew faces detected which may impair the quality of the results
<<Writing 1779 skew faces to set skewFaces
*There are 61015 faces with concave angles between consecutive edges. Max concave angle = 79.996085418 degrees.
<<Writing 61015 faces with concave angles to set concaveFaces
Face flatness (1 = flat, 0 = butterfly) : average = 0.992414013125 min = 0.201691375183
*There are 10729 faces with ratio between projected and actual area < 0.8
Minimum ratio (minimum flatness, maximum warpage) = 0.201691375183
<<Writing 10729 warped faces to set warpedFaces
Failed 2 mesh checks.
Why? Is reconstructParMesh the culprit?
doubtsincfd is offline   Reply With Quote
Problem with reconstructPar usergk OpenFOAM 0 December 13, 2010 17:52
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
CFX Casting problem: Can it be done all in one? jfasl CFX 1 September 14, 2010 03:14
UDF problem due to using C_U_M1 Rachel FLUENT 0 July 15, 2008 11:13
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
