How to add steger warming flux vector splitting in open foam |
dushyant bajaj
Rep Power: 14 ![]() |
Hiii,
I am new to open foam and want to add steger warming flux vector splitting in it. Can any one tell me the process of adding? thanks in advance |
You can modify rhoCentralFoam to add steger-warming fluxes. Thats what I did here
http://gfoam.svn.sourceforge.net/ though I have not added that particular flux. |
venkat
Rep Power: 15 ![]() |
I am also looking for the above procedure.
thank you very much, helpful for many users Regards, |
venkat
thank you very much, it is helpful for many users Regards, |
dushyant
Hiiii Praveen , thanks for your reply but i am currently working on openfoam 2.00 version. By seeing your link i am totally confused. Is it possible to send me some reference code (related to flux vector splitting) that u had done. It will really help me a lot. My mail id dushyantbajaj1984@gmail.com
Thanks & Regards Dushyant |
dushyant bajaj
Hiiii nimasam
Thanks for showing your interest -- I had written a implicit code in c for the steger warming splitting . Now i want to add this scheme in OpenFoam as existing one like rhocentralfoam. So i need to know the process of doing it. I understood the oblique shock reflection problem solved using rhoCentralfoam but now i dnt know how to add my scheme and test this problem. |
#10 |
venkat
I excuted programmes given in the the above link, no problem with wmake but i am getteing the following errors when running with solver,
can you please tell me how to fix the following errors: Build : 1.7.x-4bbf33160caf Exec : newSolver Date : Jul 06 2011 Time : 16:27:25 Host : ishitha-Inspiron-1564 PID : 2709 Case : /opt/openfoam171/applications/solvers/compressible/gFoam/rhoCentralFoam/forwardStep nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> Reading field U Reading thermophysicalProperties fluxScheme: LxF Starting time loop #0 Foam::error: ![]() #1 Foam::sigSegv::sigSegvHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 in "/root/OpenFOAM/root-1.7.1/applications/bin/linuxGccDPOpt/newSolver" #4 in "/root/OpenFOAM/root-1.7.1/applications/bin/linuxGccDPOpt/newSolver" #5 __libc_start_main in "/lib/libc.so.6" #6 in "/root/OpenFOAM/root-1.7.1/applications/bin/linuxGccDPOpt/newSolver" Segmentation fault thanking you, venkat. Last edited by venkataramana; July 6, 2011 at 07:12. Reason: typing errors |
#11 | |
ana
Rep Power: 0 ![]() |
#12 |
An Open Source mesh generator for Open Foam | Ahmed | Main CFD Forum | 15 | September 23, 2010 18:39 |
How to add a flux source to SIMPLEfoam | ehsan_vaghefi | OpenFOAM Running, Solving & CFD | 0 | September 29, 2008 21:19 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
problem in running FoamX in Open FOAM | Gaurav | Main CFD Forum | 3 | May 10, 2006 05:06 |
Some questions about Open Foam | cicciopasticcio | OpenFOAM Running, Solving & CFD | 0 | December 17, 2005 08:41 |
