Reading Co-ordinates from a file for blockMesh |
June 28, 2011, 06:30 |
Fu
Greetings !
Is there any way I can read the coordinates from a file rather than using simpleGrading in blockMesh . To make my point clear , I have an uniform mesh in streamwise (say x) and spanwise (say z) directions in a channel and the third direction which is non-uniform (say y) co-ordinate is to be read from a file. Can i do it by tweaking the blockMeshDict file ?. I will be more than happy if i can generate using an expression (Say, Tanh or Sinh functions) inside blockMeshDict Thanks and Regards fu-ki-pa |
June 28, 2011, 06:45 |
Bernhard
Rep Power: 21 |
This is not possible with the original blockMesh afaik. But if you make your own utility, based on this blockMesh, you will definitely be able to do something like this.
June 29, 2011, 05:20 |
#3 | |
Mark Olesen
Rep Power: 40 |
You'll also notice that blockMesh now has its own library routines (see http://repo.or.cz/w/OpenFOAM-2.0.x.g...mesh/blockMesh) which should make this type of customization somewhat easier. |
blockmesh, complexgrading, read file, tanh |
[Commercial meshers] Problem converting fluent mesh | vinz | OpenFOAM Meshing & Mesh Conversion | 28 | October 12, 2015 06:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
