Average of Scalar of a cellset during the calculation for each time step |
June 30, 2011, 06:20 |
Sam Fredriksson
Rep Power: 15 |
Hello
I would like to monitor as well as later on post process spatial averages of scalar fields. My strategy was to collect the cells to be averaged in different cellSets. I would then like to average a number of scalar fields for each of these cellSets during my computation. Is there someone who have done this before and can give a hint on how to do this? Best regards, Sam |
June 30, 2011, 17:35 |
David Gaden
Rep Power: 22 |
I don't know much about cellSets, but you could add an IOdictionary to the createFields, except instead of MUST_READ and NO_WRITE, set it to NO_READ, and AUTO_WRITE, and put it in runTime.timeName() instead of constant. Then fill it with the average values for each variable for each cellSet at every time step. e.g. myDict.set(varName, average(scalarField)); << very rough
That way it will output your dictionary to the time directories with average values. |
October 4, 2011, 17:13 |
Thank you for your help
Sam Fredriksson
Rep Power: 15 |
Thank you for your help!
October 7, 2011, 11:15 |
Average a cellSet during the run with cellSource
Frederic Collonval
Location: Technische Universitaet Munich - Lehrstuhl fuer Thermodynamik
Rep Power: 17 |
Hello Sam,
There is a non-intrusive & nice way to do it by using the cellSource. The explanation in the code is Code:
00024 Class 00025 Foam::fieldValues::cellSource 00026 00027 Description 00028 Cell source variant of field value function object. Values of user- 00029 specified fields reported for collections of cells. 00030 00031 cellObj1 // Name also used to identify output folder 00032 { 00033 type cellSource; 00034 functionObjectLibs ("libfieldValueFunctionObjects.so"); 00035 enabled true; 00036 outputControl outputTime; 00037 log true; // log to screen? 00038 valueOutput true; // Write values at run-time output times? 00039 source cellZone; // Type of cell source or all for the full domain 00040 sourceName c0; 00041 operation volAverage; 00042 fields 00043 ( 00044 p 00045 U 00046 ); 00047 } 00048 00049 where operation is one of: 00050 - none 00051 - sum 00052 - volAverage 00053 - volIntegrate 00054 - weightedAverage HRR { type cellSource; functionObjectLibs ("libfieldFunctionObjects.so"); enabled false; outputControl timeStep; outputInterval 1; log true; // log to screen? valueOutput false; // Write values at run-time output times? source all; // cellZone or all sourceName c0; operation volIntegrate; fields ( dQf ); } Good luck Frederic N.B.: A cellSet is maybe not working directly, you may have to convert it into cellZone. For that there is the tool setsToZones
Frederic Collonval Technische Universität München Thermodynamics Dpt. |
October 11, 2011, 10:28 |
This looks very promising - thank you!
Sam Fredriksson
Rep Power: 15 |
August 12, 2012, 03:31 |
ak
Rep Power: 15 |
Hi Frederick,
I am a new user of OF, and would appreciate if you could clear the following doubts (based on the volume integral code provided): How are the cell sources/cell zones defined? What does c0 refer to? Thanks, ak |
August 14, 2012, 03:31 |
Frederic Collonval
Rep Power: 17 |
Hi ak,
To create cell zone, you have to create cell set using 'setSet'. Then using the same tool, you can convert a cell set in cell zone. Go to a case directory. Type the command 'setSet' - it looks like a console software. Type 'help' to get more information and examples. N.B.: To know which 'source's are available, type something like Code:
cellSet c0 new dummy Cheers, Frederic
August 14, 2012, 13:15 |
#9 |
ak
Rep Power: 15 |
Hello
Thanks for the prompt reply. It is very useful. I tried the following: 1. Created makeCellSets.setSet file with the following details: cellSet combustor new boxToCell (-0.02 0 0) (0 0.025 0.04) cellSet combustor add boxToCell (0 -0.025 0) (0.2 0.025 0.04) cellZoneSet combustorZone new setToCellZone combustor 2. Then, using an Allrun script, the following was performed: runApplication blockMesh runApplication setSet -batch makeCellSets.setSet rm -f constant/polyMesh/sets/*_old runApplication setsToZones -noFlipMap 3. In system/controlDict, the following was included: HRR { type cellSource; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl timeStep; outputInterval 1; log false; // log to screen? valueOutput false; // Write values at run-time output times? source cellZone; // cellZone or all sourceName combustorZone; operation volIntegrate; fields ( p // For testing U // For testing chemistrySh ); } While this worked for volIntegrate for p and U (just for testing code), the HRR/0/cellSource.dat file had no data for chemistrySh # Source : cellZone combustorZone # Cells : 258720 # Time sum(V) volIntegrate(p) volIntegrate(U) volIntegrate(chemistrySh) 2e-06 0.00042 41.9985 (-1.51726e-05 -1.78689e-07 9.04692e-20) 4e-06 0.00042 42.0006 (-1.95745e-05 -2.44872e-07 -1.95267e-19) 6e-06 0.00042 42.0038 (-8.04091e-06 -2.64433e-07 -2.09461e-16) The cellSet and cellZone approach as you suggested works quite well. Thanks! I am not sure though why it is not able to record the volume Integral of chemistrySh using this approach. In the solver, when I use fvc::domainIntegrate(chemistrySh).value(), it works just fine and can output the result in the terminal as well. Could you let me know how you define dQf in your code, or what could be wrong with my approach? In my createFields, I have: volScalarField chemistrySh // DimensionedField<scalar, volMesh> chemistrySh ( IOobject ( "chemistry::Sh", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensionedScalar("chemistrySh", dimEnergy/dimTime/dimVolume, 0.0) ); Thanks! ak |
August 14, 2012, 14:06 |
#10 |
ak
Rep Power: 15 |
Hi
Got this figured out: Defined chemistrySh as follows: volScalarField chemistrySh ( IOobject ( "chemistrySh", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); A 0/chemistrySh file was also required in the case directory. I should also add another way to calculate the volume integral, as follows: volHRR { type volumeIntegrate; functionObjectLibs ("libsimpleFunctionObjects.so"); enabled true; outputControl timeStep; outputInterval 1; log false; // log to screen? valueOutput false; // Write values at run-time output times? fields ( chemistrySh ); } -ak |
August 14, 2012, 16:38 |
#11 |
ak
Rep Power: 15 |
Hi
I am now having difficulty printing out the data when I run computations in parallel. Any ideas how to proceed? ak Edit. When I use the 2nd option above, it says: Can only probe registered volScalar, volVector, volSphericalTensor, volSymmTensor and volTensor fields Last edited by newOFuser; August 14, 2012 at 17:16. |
August 15, 2012, 04:11 |
Save heat release
#12 |
Frederic Collonval
Rep Power: 17 |
Hi ak,
The second option is a good idea. But I advice you to use a name totally different like "heatRelease". Then it should work as you wrote it i.e. using a volScalarField storing Sh (the error can come when you try to integrate the DimensionedField<scalar, volMesh> for example). To print output for all processors, you have to use 'Pout' instead of 'Info'. Best regards, Frederic
August 15, 2012, 10:32 |
#13 |
ak
Rep Power: 15 |
Hello
Thanks for the suggestions, and all the help! I was able to get it to run in parallel mode. Thanks, ak Last edited by newOFuser; August 15, 2012 at 16:22. |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 09:20 |
calculation of time step | aamer | Main CFD Forum | 8 | December 8, 2010 03:26 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
