July 6, 2011, 01:21 |
rhoCentralFoam Solver
venkat
Rep Power: 15 |
hi all,
here i am using a new scheme with rhoCentralFoam Solver, it is compiling without problems, while running the code there are errors given below, Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> Reading field U Reading thermophysicalProperties fluxScheme: newScheme Starting time loop #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 in "/root/OpenFOAM/root-1.7.1/applications/bin/linuxGccDPOpt/newSolver" #4 in "/root/OpenFOAM/root-1.7.1/applications/bin/linuxGccDPOpt/newSolver" #5 in "/root/OpenFOAM/root-1.7.1/applications/bin/linuxGccDPOpt/newSolver" #6 __libc_start_main in "/lib/libc.so.6" #7 in "/root/OpenFOAM/root-1.7.1/applications/bin/linuxGccDPOpt/newSolver" Segmentation fault Regards Venkat |
July 6, 2011, 03:25 |
Rickard
Rep Power: 16 |
Printstack is usually divide by zero.
Did you try changing some of the conditions in your 0-directory? Otherwise, it might just be some mesh problem, try to run blockMesh again or something like this. |
July 6, 2011, 05:07 |
hi Rickard,
venkat
Rep Power: 15 |
thanks for your reply,
no errors with blockMesh, |
July 20, 2011, 09:58 |
Problem to generate the mesh
R. P.
Rep Power: 15 |
hello everybody,
I'm using the rhoCentral Foam (2.0 version) and I have been problems to generate my mesh. My mesh is composed by two regions, the first one is rectangular and the second one is a parallelepiped. For the region when I run the commands blockMesh and checkMesh everything is ok, but when I introduce the second region the openFoam give the following error: "number of edges not aligned or perpendicular to non-empty directions". I substituted the parallelepiped region for other rectangular region and everything works fine. Maybe the openFoam don't accept angles in the mesh ? Somebody could help me ? Thanks |
A New Solver for Supersonic Combustion | nakul | OpenFOAM Announcements from Other Sources | 19 | February 27, 2024 09:44 |
[Other] A New Solver for Supersonic Combustion | nakul | OpenFOAM Community Contributions | 20 | February 22, 2019 09:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Development of a Low mach PISO solver | nishant_hull | OpenFOAM Programming & Development | 0 | August 25, 2009 12:48 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
