July 27, 2011, 19:52 |
Viewing multiregion results
Mirko Vukovic
I am running OF2.0. When I run a multi-region tutorial, such as multiRegionHeater, I cannot view calculated values in ParaView 3.10.1 When I select time-step 0, I can see the list of calculated fields in paraview's Volume Fields window. When I select other time-steps, the Volume Fields becomes zero, and I cannot view any other fields (pressure, temperature, velocity). Any idea what could be wrong? Thank you, Mirko |
July 28, 2011, 07:48 |
Joel Lehikoinen
In the case dir, run
foamToVTK -region <region_name> |
July 29, 2011, 15:04 |
#3 | |
Mirko Vukovic
Mirko |
September 21, 2011, 06:02 |
multiRegion post processing
Sebastian
A much easier way ist the following:
open Paraview by typing Code:
paraFoam -region region1 Then generate a wrapping File for the second region Code:
touch caseName{region2}.openFoam This file must be opened with paraview and the region2 will appear. Greetings Sebastian |
Viewing results of chtMultiRegion in paraFoam | Scot | OpenFOAM | 2 | April 22, 2011 16:29 |
Viewing the Results problem | kurne | OpenFOAM Running, Solving & CFD | 0 | December 2, 2010 08:33 |
problems viewing results with VNC | Ralf Schmidt | FLUENT | 3 | February 1, 2006 01:40 |
Error in viewing results | Mukund | FLUENT | 5 | August 6, 2005 04:04 |
Suitability of OpenDX for viewing CFX 4.3 results | Jonathan Wall | CFX | 3 | April 4, 2000 08:09 |
