Problem with rhoPorousMRFSimpleFoam and how to define porous media
Old   July 29, 2011, 02:46
Default Problem with rhoPorousMRFSimpleFoam and how to define porous media
Amit Mathur
Amit Mathur is on a distinguished road
Dear All,
I am facing problem while running rhoPorousSimpleFoam solver in OpenFoam 2.0.x. I am trying to simulate pressure driven flows (Pressure is fixed boundary condition at inlet and outlet) in a simple pipe with porous zone. The K-Epsilon turbulence model is used. The solver is oscillating with higher values of epsilon on boundary. I am also facing problem in defining Porous media. If some one have some document regarding to that please send to me.
In some cases it runs by making so many changes in relaxation parameters etc. But the results are not validated, especially the pressure drop across the porous media both for isotropic and anisotropic cases. I am copying below the porous zone file defined for isotropic(homogeneous) porous media.
1
cellTable_8
coordinateSystem
e1 (0.90709 0.295279 0.299993);
e2 (-0.329827 0.033477 0.943447);
Darcy
d d [0 -2 0 0 0 0 0] (1.14e8 -1 -1);
f f [0 -1 0 0 0 0 0] (422.955 422.955 422.955);
thermalModel
type none; // fixedTemperature;
// fixedTemperature coefficients
T 350;
It is not in the stars to hold our destiny but in ourselves
Regards
Amit Mathur
Amit Mathur is offline   Reply With Quote
Old   July 19, 2012, 11:19
Kalyan
kalyangoparaju is on a distinguished road
Amit,
Did you solve your problem.
I am assuming that you have a high relaxation factor for epsilon. Decreasing it might help. If not, try to change the initial values of epsilon.
Also, to crenate a porousZone from a mesh not built in foam, you need to create cellSet and then convert it to a cellZone using setSet function.
Kalyan
kalyangoparaju is offline   Reply With Quote
Old   July 17, 2013, 06:18
Default Meaning of value in porous zone file
mech01 is on a distinguished road
Hi can any one tell me what is ment by 1 in porouse zone file. Is it default value of porosity. or it mean one cell zone or one block.
Thanks
mech01 is offline   Reply With Quote
Old   July 18, 2013, 00:57
Akshay Kumar
Akshay is on a distinguished road
Hi mech01
It is the latter.
Akshay is offline   Reply With Quote
Old   July 18, 2013, 05:05
Originally Posted by Akshay View Post
Hi mech01
It is the latter.
Latter means its one block
Old   July 18, 2013, 05:23
Akshay Kumar
Absolutely...it means you are defining only one zone i.e cellTable_8
Old   July 18, 2013, 06:57
Thank you Akshay
