localEuler in rhoCentralFoam
Like Tree4Likes
  • 3 Post By praveen
  • 1 Post By laurensvd
Old   August 3, 2011, 05:49
Default localEuler in rhoCentralFoam
Praveen. C
praveen is on a distinguished road
In order to do steady state calculations with rhoCentralFoam, I am trying to use localEuler ddt scheme. From what I understood, this requires specifying rDeltaT as a volScalarField. I have made following additions to rhoCentralFoam in version 2.0.0
createField.H:
volScalarField rDeltaT
    IOobject
        "rDeltaT",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
    mesh,
    1/dimensionedScalar("maxDeltaT", dimTime, GREAT),
    zeroGradientFvPatchScalarField::typeName
setrDeltaT.H:
    // Set the reciprocal time-step from the local Courant number
    rDeltaT.dimensionedInternalField() = max
        1/dimensionedScalar("maxDeltaT", dimTime, maxDeltaT),
        fvc::surfaceSum(amaxSf)().dimensionedInternalField()
       /(maxCo*mesh.V())
    // Update tho boundary values of the reciprocal time-step
    rDeltaT.correctBoundaryConditions();
rhoCentralFoam.C:
        surfaceScalarField aphiv_pos(phiv_pos - aSf);
        surfaceScalarField aphiv_neg(phiv_neg + aSf);
        // Reuse amaxSf for the maximum positive and negative fluxes
        // estimated by the central scheme
        amaxSf = max(mag(aphiv_pos), mag(aphiv_neg));
        #include "compressibleCourantNo.H"
        #include "readTimeControls.H"
        //#include "setDeltaT.H"
        #include "setrDeltaT.H"
        runTime++;
        Info<< "Time = " << runTime.timeName() << nl << endl;
Then in system/fvSchemes, I specify
ddtSchemes
    default         localEuler  rDeltaT;
The code compiles and runs but blows up after some iterations. With the usual rhoCentralFoam it runs fine, but it takes forever to converge. I use a maxCo of 0.1 and it is a subsonic flow. Limiters are also used (Gamma scheme). I could not find anything on localEuler in the forums so I want to know if anybody has succeeded in using it, or if you can find any mistake in my modifications.
praveen is offline   Reply With Quote
Old   September 10, 2011, 14:18
ramhari is on a distinguished road
@praveen
http://www.cfd-online.com/Forums/ope...time-step.html
In the above thread, check my last post (which is working fine for me )...U may get some idea : )
Cheers!
Hariram
ramhari is offline   Reply With Quote
Old   January 9, 2012, 14:06
Eric M. Tridas
eric.m.tridas is on a distinguished road
Praveen,
Have you had any more success implementing the localEuler ddt scheme? I am very interested in this aspect as my simulations using rhoCentralFoam are take ages to compute.
Thanks,
-Eric
eric.m.tridas is offline   Reply With Quote
Old   February 23, 2012, 10:31
Laurens Van Dyck
laurensvd is on a distinguished road
Im not sure if the poster is still following this but if you are, where did you get that definition for rDeltaT?
fvc::surfaceSum(amaxSf)().dimensionedInternalField()        /(maxCo*mesh.V())
If you look at the compressible courant number definition it is formulated differently:
surfaceScalarField amaxSfbyDelta
        mesh.surfaceInterpolation::deltaCoeffs()*amaxSf
    CoNum = max(amaxSfbyDelta/mesh.magSf()).value()*runTime.deltaTValue();
I am trying to implement this latter equation to get rDeltaT but I am unable to get the syntax right to find the amaxSfbyDelta/mesh.magSf() for each cell. How can I find the maximum number of that value (which is I Presume calculated over the cell faces).
In other words, is there a command that finds the maximum surface value of a cell?
My current (not completely correct) implementation for rDeltaT is the following:
fvc::surfaceSum(mag(amaxSfbyDelta/mesh.magSf()))/(2.0*maxCo)
Since I did not know how to find the maximum surface value of a cell I performed a surface sum of the magnitude and then divided it by 2 to get approximately the same effect as the initial definition of the compressible courant number.
When you look at the interFoamLTS source code you can also find how to implement smoothing over the rDeltaT field which you might consider implementing if you have big differences in timestep between neighboring cells.
mm.abdollahzadeh likes this.
laurensvd is offline   Reply With Quote
Old   October 21, 2012, 02:19
Praveen. C
Suppose \lambda_{ij} is maximum wave speed in the face normal direction across the face between cell i and cell j. Let \Delta s_{ij} be area of this face. Then time step in cell i should be
\Delta t_i \le \frac{V_i}{\sum_j \lambda_{ij} \Delta s_{ij}}
where the sum is over all face neighbouring cells of cell i.
Introducing a courant number maxCo, we get
\frac{1}{\Delta t_i} = \frac{\sum_j \lambda_{ij} \Delta s_{ij}}{maxCo * V_i}
The time step condition can be seen by applying first order upwind scheme to a scalar convection equation.
NACA0012 with rhoCentralFoam praveen OpenFOAM 17 July 5, 2018 05:49
rhoCentralFoam with totalPressure/totalTemperature at inlet of subsonic channel deepblue17 OpenFOAM Running, Solving & CFD 5 February 11, 2013 02:42
Hypersonic flow rhoCentralFoam ishaninair OpenFOAM Running, Solving & CFD 0 April 7, 2011 04:38
Always crash when solve a C-D nozzle flow field using rhoCentralFoam hawklion OpenFOAM Running, Solving & CFD 0 March 9, 2011 06:13
