openFoam syntax
Like Tree5Likes
  • 1 Post By nimasam
  • 4 Post By marupio
Old   September 29, 2011, 15:27
Default openFoam syntax
Nima Samkhaniani
nimasam is on a distinguished road
hi openFoamer
in compressibleInterFoam and in pEqn.H there are following syntax:
 dgdt =
                (pos(alpha2)*(psi2/rho2) - pos(alpha1)*(psi1/rho1))
               *(pEqnComp & p);
can any body tell me whats the meaning of "pEqnComp & p" ?
pEqnComp : fvScalarMatrix
p : volScalarField
so whats "&" here ?
alia likes this.
nimasam is offline   Reply With Quote
Old   September 29, 2011, 20:30
David Gaden
marupio is on a distinguished road
I think it's the inner product.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   September 29, 2011, 21:57
Nima Samkhaniani
im confused how we can inner product fvScalarMatrix with volScalarField?
what is the output and how this calculation can be done? give me a mathematical concept please
Old   September 29, 2011, 22:39
David Gaden
fvMatrix.C implements operator& around line 2270. The result is a GeometricField. I'm not exactly sure what it does, but it looks like it affects the matrix. I don't have my Foaming computer in front of me at the moment.
Old   September 30, 2011, 05:45
Nima Samkhaniani
& operator is defined in fvMatrix.C like below:
template<class Type>
Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> >
Foam::operator&
    const fvMatrix<Type>& M,
    const DimensionedField<Type, volMesh>& psi
    tmp<GeometricField<Type, fvPatchField, volMesh> > tMphi
        new GeometricField<Type, fvPatchField, volMesh>
            IOobject
                "M&" + psi.name(),
                psi.instance(),
                psi.mesh(),
                IOobject::NO_READ,
                IOobject::NO_WRITE
            psi.mesh(),
            M.dimensions()/dimVol,
            zeroGradientFvPatchScalarField::typeName
    GeometricField<Type, fvPatchField, volMesh>& Mphi = tMphi();
    // Loop over field components
    for (direction cmpt=0; cmpt<pTraits<Type>::nComponents; cmpt++)
        scalarField psiCmpt = psi.field().component(cmpt);
        scalarField boundaryDiagCmpt(M.diag());
        M.addBoundaryDiag(boundaryDiagCmpt, cmpt);
        Mphi.internalField().replace(cmpt, -boundaryDiagCmpt*psiCmpt);
    Mphi.internalField() += M.lduMatrix::H(psi.field()) + M.source();
    M.addBoundarySource(Mphi.internalField());
    Mphi.internalField() /= -psi.mesh().V();
    Mphi.correctBoundaryConditions();
    return tMphi;
1) could you please tell me what does this piece of code do?
it seems it loops over the field to make it diagonal predominate, but its confusing!
2)why it returns tMphi while it does all operation on Mphi? i feel it should be Mphi
Old   September 30, 2011, 06:02
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
add 2) tMphi is a tmp<Type>, whereas Mphi (of type Type) is a reference to tMphi. Hence all changes to Mphi is directly a change to tMphi.
tMphi is returned, as the tmp class is included in OpenFOAM to optimise the memory handling. Since volFieldsType> can potentially be very large, the return of a tmp<volField<Type> > speeds up the run-time.
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   September 30, 2011, 09:33
David Gaden
It's probably the inner product. When it involves a fvMatrix, it apparently does something to the Matrix's diagonal. I'm not going to try to decode it because I agree: it is confusing.
Old   September 30, 2011, 12:26
David Gaden
Hi Nima, sorry for being dismissive in the last response. If you want to go into detail about what the & operator does, I've added some comments in blue that might help you out. It looks like it doesn't actually affect the matrix. It looks like it is the inner product between the field associated with the matirx, with the field p you mention. Since a matrix is involved, it has to account for boundary conditions, and I think that's where it gets confusing, especially when it comes to boundary patches that have out-of-core multiplication (cyclic, processor, etc). Also see below for links to useful pages that might help further explain things.
Foam::operator&
    // Here we create the return object
            IOobject
                "M&" + psi.name(),
                psi.instance(),
                psi.mesh(),
                IOobject::NO_READ,
                IOobject::NO_WRITE
            psi.mesh(),
    // This is for convenience, because it is awkward dealing directly with tmp<>
    // See link below.
        // psiCmpt is your "p"
        // Here we're grabbing a copy of the matrix diagonal of your "pEqnComp"
        // This function brings in out-of-core multiplication effects from the boundary
        // (e.g. cyclic patches) and puts it into our copy of the diagonal
        // Multiplying p by the modified diagonal, store result in output object
    // H operator stuff.  Shorthand operation built into the matrix that I never
    // remember what it does... see link below
    // Per unit volume - the matrix is integrated over the volume; a field is not
    return tMphi;
For H operator stuff, see this page:
http://openfoamwiki.net/index.php/Op...ide/H_operator
For what tmp<> is all about, see here:
http://openfoamwiki.net/index.php/OpenFOAM_guide/tmp
nlc, nimasam, alia and 1 others like this.
equation, operator, syntax
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
OpenFOAM file syntax amtri OpenFOAM 5 August 28, 2010 07:19
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
