how to output hi in OpenFoam
Like Tree1Likes
  • 1 Post By mturcios777
Old   October 24, 2011, 04:56
Default how to output hi in OpenFoam
yi Wang
yiwang25 is on a distinguished road
hello,everyone
In Openfoam, How to output speices specific enthalpy hi?
Any comments, please
yiwang25 is offline   Reply With Quote
Old   October 24, 2011, 12:12
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Read this section of the manual on run time code compilation:
http://www.openfoam.com/version2.0.0...me-control.php
In the source code for a particular solver you specify which fields to write out when they are created, usually createFields.C. If you want the specific enthalpy of each species, you need to execute code at run-time that will write out the h field for every field i. Most likely you need to create a reference to each field with its own name (in a forAll loop) and then execute an hi.write(). You'll have to specify an interval at which these fields will be written.
mgg likes this.
mturcios777 is offline   Reply With Quote
Old   October 27, 2011, 04:31
yi Wang
mturcios777:
Thank you very much! would you like to show me an example?
Old   October 27, 2011, 13:57
Marco A. Turcios
Of the top of my head, it seems like you'll need something like this:
label specName;
foAll(h,speci)
    specName = h[i].name();
    volScalarField hiTemp
    IOobject
        specName,
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
    h[i]
    hiTemp.write();
Not being super familiar with runTime post-processing, I'm not exactly sure where this should be located, but it seems like you should try adapt the fourth example on the OpenFOAM page I linked earlier (the one that calculated the average pressure). Change the outputControl to something that will write at the writeInterval (don't know what the option is, it may well be writeInterval). Good luck
Last edited by mturcios777; October 27, 2011 at 14:01. Reason: functionObjects comment
Old   October 28, 2011, 04:16
yi Wang
Thanks a lot. I will try
Old   January 31, 2012, 05:02
feichi.Zhang
fezh is on a distinguished road
Do you have find h_i of the species? And how? Thanks.
fezh is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 05:51
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 7 July 30, 2009 03:14
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 09:33
