heat source in solid
Like Tree3Likes
  • 1 Post By MarkW
  • 2 Post By nimasam
Old   November 24, 2011, 10:02
Question heat source in solid
MarkW is on a distinguished road
Hello there,
I'm trying to simulate the heat transfer in a piece of metal, which is heated by an electric current.
I already got a little bit familiar with laplacianFoam, is there some way to model a heat source inside of it?
Or do I have to use a different solver?
Thanks a lot!
mizzou likes this.
MarkW is offline   Reply With Quote
Old   November 25, 2011, 01:34
Default heat source in laplacianFoam
Nima Samkhaniani
nimasam is on a distinguished road
you can model heat source! just by add a source term to the laplacianFoam equation
in creatFields.H
    volScalarField q
        IOobject
            "q",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::NO_WRITE
        mesh
in laplacianFoam.C
fvm::ddt(T) - fvm::laplacian(DT, T) - q
then you should compile your solver with "wmake"! (look user guide)
then in your case study in folder zero you should add a file name "q"
you can apply different value from uniform or non-uniform heat source
for making the initial non uniform heat source use "setFields" or "funkySetFields"
for install "funkySetField", look at here:
http://openfoamwiki.net/index.php/Co...funkySetFields
mizzou and dasa like this.
nimasam is offline   Reply With Quote
Old   November 25, 2011, 08:19
Thanks a lot!
This approach saves me a lot of time!
heat source, heat transfer, laplacian, solid objects
how to load the heat source to wall david yang Main CFD Forum 1 October 12, 2009 13:34
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
