Foil Bearing Simulation
Old   November 25, 2011, 01:34
Red face Foil Bearing Simulation
Balaji Sankar
Bajji is on a distinguished road
I have to simulate the orbit(path taken by the centre ) of the shaft in a foil bearing with air as the lubricant instead of oil. The foil bearing is same as the Journal bearing except that the boundary is deformable and not rigid like a journal bearing. There is a pressure build up because shaft is rotating and dragging the air around it into a narrow channel.(See image) I obviously need to solve the
a) Pressure build up in the fluid
b) Deformation of the boundary due to the built up pressure.
c) Motion of the shaft centre inside the bearing in response to the pressure and its own rotation.
Hope I am clear.
1) Has anyone solved this in OpenFOAM before.?
2) what are the solvers I should read up on?
Any pointers to start or links to similar solved problems will be very usefull.
Bajji is offline   Reply With Quote
Old   November 25, 2011, 03:32
Elvis
elvis will become famous soon enough
maybe http://powerlab.fsb.hr/ped/kturbo/Op...dicPhD2005.pdf
Doctorate Thesis: Advanced Modelling of Elastohydrodynamic Lubrication by
Petra Brajdic-Mitidieri
http://powerlab.fsb.hr/ped/kturbo/Op...riImperial.pdf
is something for you
elvis is offline   Reply With Quote
Old   November 28, 2011, 03:20
Smile
Balaji Sankar
Thanks Elvis.
I will see what Brajdic has done in his Thesis.
Old   May 1, 2013, 09:20
Default Help
Fabian
fpierart is on a distinguished road
Originally Posted by Bajji View Post
Thanks Elvis.
Bajji, could you finally model the bearing?, I need to do the same and if you can help me, with something like with solver did you use (rhoSimplecFoam, rhoCentral foam) or more datails I will be very helpull.
fpierart is offline   Reply With Quote
Old   May 1, 2013, 23:47
Default Couldn't do it in openFOAM.
Balaji Sankar
Hi fpierart,
I did finally model the bearing with shaft motion inside it.
But I gave up on openFOAM and wrote the Reynold's equation solver (I tried FDM and FVM) in C++ from scratch. It worked. I got pretty good agreements between simulated and published pressure distributions at mid plane.
I want to make clear that it was not a problem with openFOAM. I simply couldn't get that monster working.
Have great time,
Balaji Sankar.
bearings, fsi, openfoam, shaft dynamics
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
problem is modeling and simulation of an air foil alnabhani CFX 4 December 2, 2010 13:24
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 18:57
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
