Operate on volScalarField as whole v access elements
Old   January 14, 2012, 08:19
Default Operate on volScalarField as whole v access elements
Adhiraj
adhiraj is on a distinguished road
Hi all,
If I have a volScalarField that is formed by doing something (adding, dividing, taking square roots etc) of some other volScalarFields, should I do those operations element by element, or on the whole thing at one go?
I have the element by element version implemented, and was wondering if I could get a speedup by using the other option.
adhiraj is offline   Reply With Quote
Old   November 29, 2012, 08:25
Awais Ali
owayz is on a distinguished road
Send a message via MSN to owayz
Hi adhiraj,
Yes you can do it as a whole. For some example you can see the yPlus utility and check how yPlus is being calculated.
Can you kindly share how did you do all the operations element wise.
regards,
Awais
owayz is offline   Reply With Quote
Old   November 29, 2012, 12:35
Adhiraj
Yes, I found that I can operate on the whole thing at once, too.
I did that and I don't know if it is more efficient or anything--the code is certainly cleaner and easier to read.
I did something like
A.internalField()[celli]=std::sqrt(B.internalField()[celli]);
or similar.
[ICEM] Hybrid mesh for 2D boundary layer Bigio ANSYS Meshing & Geometry 33 November 18, 2019 09:15
Access a volScalarField from BC code Hisham OpenFOAM Programming & Development 6 November 25, 2011 15:33
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 08:06
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
