Error when using blockMesh
Old   January 31, 2012, 14:37
Default Error when using blockMesh
maybee is on a distinguished road
hi,
I want to run blockMesh over a blockMechDict file, but I get the following error message:
frighter@frighter-System-Product-Name-System-Product-Name:~$ '/home/frighter/j/constant/polyMesh/blockMeshDict'
bash: /home/frighter/j/constant/polyMesh/blockMeshDict: no right
frighter@frighter-System-Product-Name-System-Product-Name:~$ blockMesh
|  \\    /   O peration     | Version:  2.1.0                                 |
Build  : 2.1.0-0bc225064152
Exec   : blockMesh
Date   : Jan 31 2012
Time   : 20:05:31
Host   : "frighter-System-Product-Name-System-Product-Name"
PID    : 8051
Case   : /home/frighter
nProcs : 1
Create time
fileName::stripInvalid() called for invalid fileName UbuntuOne
    For debug level (= 2) > 1 this is considered fatal
Stopped
I am not sure if this is a problem with OpenFoam or my user rights. Does someone have a tip?
greetings
maybee
maybee is offline   Reply With Quote
Old   January 31, 2012, 14:42
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by maybee View Post
hi,
Exec   : blockMesh
Date   : Jan 31 2012
Time   : 20:05:31
PID    : 8051
nProcs : 1
Create time
Stopped
greetings
maybee
That's a classic PEBCAK (Problem exists between chair and keyboard). According to your output you are running blockMesh in your $HOME while the case is in $HOME/j. Either go to the case directory and run blockMesh there or use the -case-option
gschaider is offline   Reply With Quote
Old   January 31, 2012, 15:15
Damn, I forgot cd . LOL. thx - problem solved.
[blockMesh] blockMesh - help atareen64 OpenFOAM Meshing & Mesh Conversion 3 June 14, 2017 11:21
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh colinB OpenFOAM Meshing & Mesh Conversion 8 January 22, 2012 10:32
Face orientation in blockMesh WiWo OpenFOAM 0 March 18, 2010 11:10
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
