March 5, 2012, 13:10 |
Hydraucone Draft Tube CFD
Tony M.
I own an old watermill in the east of France. I am in the process of installing a new 1.8m diameter Kaplan Hydro Turbine with a flow of 10 cubic metres per second. Because of space constraints it would not be easy to install a conventional elbow Draft Tube. I have come across a more compact form of Draft Tube known as White's Hydraucone Draft Tube. This is a very simple design. The water exiting the turbine is deflected by a flat plate to the walls of the chamber. The water then exits the Draft Tube underneath the deflector plate to the exit canal, the velocity having been greatly reduced. A Hydraucone Draft Tube was installed at Niagara Falls in the 1920's. Does anyone in the forum know of design parameters for a White Hydraucone ? e.g. what is the optimal spacing to the deflector plate ? Would it be possible for some kind person to run some simple CFD calculations on the effectiveness of a Hydraucone Draft Tube ? Turbine diameter: 1.8m Water Flow: 10 m3/s Velocity 3.93 m/s (possibly with some rotation) Water chamber 5m X 5m The original paper on the Hydraucone Draft Tube can be found here: http://www.frenchriverland.com/white_hydraucone_regainer.htm This might make for an interesting student CFD project or perhaps a useful learning exercise for someone new to CFD. Any assistance would be greatly appreciated. Tony M. |
draft tube, hydraucone |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
CFD job and salary? | Mingyong | Main CFD Forum | 11 | January 2, 2001 06:15 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 17:25 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 11:44 |
