multiplication of scalar and volVectorField
Old   March 26, 2012, 11:29
Default multiplication of scalar and volVectorField
mikeP is on a distinguished road
I use following two methods in order to get the multiplication of Reynolds number and drag coefficient. (Drag coefficient, Cd, here is assumed constant scalar here for convenience)
Re = (magUr*dp*rhoa)/mua;
CdRe = 0.5*Re;
forAll (Re, celli)
     CdRe[celli] = 0.5*Re[celli];
These should give the same volScalarField, CdRe.
However, when I use these two code parts, I get different velocity field results at the end.
Are these two code parts exactly the same? or can they give different results when I, let's say, interpolate them?
mikeP is offline   Reply With Quote
Old   March 26, 2012, 21:39
David Gaden
marupio is on a distinguished road
Are you sure you're dealing with a volVectorField? I didn't think you could access the internal field directly with operator[], I thought you had to use Re.field() or Re.dimensionedField() first.
You could be missing the operations on the boundaryField.
If you are dealing with vectorFields and vectors, the two pieces of code you show are equivalent, except that the indexed loop is about 10x slower. The operators are optimized with fancy pointer loops, register keywords, and special accommodations for vector machines.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   March 27, 2012, 04:12
Dear David,
I am terribly sorry, now I noticed it. It is volScalarField, of course, not volVectorField.
Indeed, at the end, velocity field at the outlet is wrong if I use the second method. So, can it be due to the fact that I do not update the boundary field?
Let me explain it a little more: I am using a modified version of bubbleFoam, where I changed the definition of drag coefficient and relative reynolds number. When I use the first example above, my velocity field is reasonable. However, this option does not allow me to modify the Cd*Re cell by cell. But when I use the second example, although it should do the same effect, it does not. Velocity values are not correct at the outlet boundary. So, do you think it may be because I do not update the boundary field? How can I get the same results in both cases?
Thank you
Old   March 27, 2012, 05:31
What I want to do is this:
Let's say I have a volScalarField Re:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "1";
    object      Re;
dimensions      [0 0 0 0 0 0 0];
internalField   nonuniform List<scalar>
5
298.831
300.729
302.117
303.149
303.901
boundaryField
    ground
        type            zeroGradient;
    top
        type            zeroGradient;
    outlet
        type            zeroGradient;
    inlet
        type            zeroGradient;
    defaultFaces
        type            empty;
Suppose I have another volScalarField CdRe. (which is the multiplication of reynolds number and drag coefficient)
I want to modify CdRe cell by cell depending on the Re values, so that I can use it in my equations.
Old   March 27, 2012, 11:49
I may have solved it.
I added this line after forall loop:
CdRe.correctBoundaryConditions();
Now it seems to be working fine.
Thank you!
Old   March 27, 2012, 12:34
David Gaden
You should try to stay away from indexed loops on the internal field whenever possible. They are slow. Try to use full-field operators.
Climbing inlet pressure with simpleFoam and directMappedPatches chegdan OpenFOAM Running, Solving & CFD 1 January 2, 2012 19:35
