Convergence problems with Steady-State algorithms
Old   March 29, 2012, 08:07
Default Convergence problems with Steady-State algorithms
andrea034 is on a distinguished road
Dear all,
I am running a simulation with a simple Naca airfoil invested by a flow (60 m/s) in a long and narrow domain.
I imposed cyclic BCs on the upper and lower bound to simulate a blade cascade.
The problem is due to the fact that, using Steady-State algorithm such as rhoSimpleFoam,
pressure residuals don't reach the desidered magnitude.
I've tried different Inlet/Outlet boundary conditions, different schemes, different relaxation factors and
to initialise the field in various ways (using for example potentialFoam and applyBoundaryLayer)
but the result is always the same.I've used both OF2.0 and OF2.1.x.
Further details:
-checkMesh is ok
-for lower speed (10-20 m/s) residuals are ok.
Any suggestion?
Thank you in advance!
andrea034 is offline   Reply With Quote
Old   March 30, 2012, 02:48
flowris is on a distinguished road
You can try more under-relaxation. Or us the SIMPLEC algorithm (rhoSimplecFoam).
flowris is offline   Reply With Quote
Old   April 2, 2012, 03:37
Thank you for your answer!
I've tried both of them but unfortunately without any significant improvement!
Old   April 2, 2012, 07:08
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
Can you try and change the cyclic's to slip BC's?
There can (from my experience) be some stability issues with the cyclic being placed this close to a wall(foil).
Also a zoom on the foil with the mesh enabled would be nice just to see what kind of resolution you have and how many cells there are between the foil and the symmetryPlane.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   April 3, 2012, 10:43
I tried the same airfoil in a larger field with slip BCs and that case reached the convergence easily...Unfortunately I must impose the cyclic BCs (I am simulating a blade cascade) and I can't enlarge the domain.
Actually I can't show you a screenshot of my mesh but there are at least 60-70 cells between the foil and the upper (or lower) boundary.
Based on your experience, could it be a good call trying to simulate the same case (same BCs) but with 3 airfoils in a 3 times larger domain?Or is it totally useless?
Thank you for help!
andrea
Old   April 13, 2012, 05:10
Dear all,
doubling the domain (and the number of airfoils) all the parameters finally reached the convergence quite easily.
I write this additional post in case someone will have to deal with similar problems.
I' d like to thank flowris and linnemann for their support.
Andrea
error message cuteapathy CFX 14 March 20, 2012 06:45
Monitor point values in a steady state simulation Kushagra CFX 2 July 13, 2008 20:03
Convergence problems Chetan FLUENT 3 April 15, 2004 19:13
Piso for steady state Andrea Siemens 11 April 19, 2002 07:33
Problems with convergence and initial guessed fields in compressible steady flows Pedro Gil Main CFD Forum 3 April 25, 2000 11:34
