[OpenFOAM] ParaView ErrOr
Old   August 16, 2013, 05:46
Default ParaView ErrOr
Soheil nazmdeh
soheil nazmdeh is on a distinguished road
Hi
i use openFoam 1.6 ext on ubuntu 12.04 .
when i run paraFoam This error seen :
Please help me to solve this error
Thanks.
ERROR :
p, li { white-space: pre-wrap; } [31mvoid DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Calculator" under id 121
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Annotate Time Filter" under id 156
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Clip" under id 123
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Contingency Statistics" under id 150
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Contour" under id 122
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Descriptive Statistics" under id 151
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Extract Level" under id 131
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Extract Selection" under id 135
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Extract Subset" under id 126
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "FOF/SOD Halo Finder" under id 133
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Glyph" under id 127
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Group Datasets" under id 130
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Histogram" under id 136
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Integrate Variables" under id 137
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Intersect Fragments" under id 147
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "K Means" under id 152
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Material Interface Filter" under id 148
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Multicorrelative Statistics" under id 153
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Particle Pathlines" under id 157
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "ParticleTracer" under id 158
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Plot Data" under id 138
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Plot Global Variables Over Time" under id 139
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Plot On Intersection Curves" under id 140
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Plot On Sorted Lines" under id 141
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Plot Over Line" under id 142
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Plot Selection Over Time" under id 143
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Principal Component Analysis" under id 154
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Probe Location" under id 144
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Programmable Filter" under id 145
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Slice" under id 124
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Stream Tracer" under id 128
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Temporal Cache" under id 159
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Temporal Interpolator" under id 160
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Temporal Shift Scale" under id 161
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Temporal Snap-to-Time-Step" under id 162
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Temporal Statistics" under id 163
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Threshold" under id 125
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Warp By Vector" under id 129
QVariantMap DBusMenuExporterDBus::getProperties(int, const QStringList&) const: Condition failed: action
soheil nazmdeh is offline   Reply With Quote
Old   August 17, 2013, 07:40
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hello Soheil,
I never use paraFoam any more, as it seems that the same functionalities are now available in the more recent versions of ParaView; including native reading of OF-formatted files.
You can find the download the binaries here:
http://www.paraview.org/paraview/resources/software.php
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 00:10
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
