[OpenFOAM] Colouring different decomposed mesh regions in paraview
Like Tree19Likes
  • 9 Post By SailorLiu
  • 7 Post By simrego
  • 2 Post By raumpolizei
  • 1 Post By louisgag
Old   January 29, 2015, 17:44
Cool Colouring different decomposed mesh regions in paraview
Yuanchuan Liu
SailorLiu is on a distinguished road
I am just wondering if paraview is able to colour different mesh regions in a decomposed case. For example, the mesh region in processor0 is red and that in processor1 is blue, etc. Just like this image in OpenFOAM website introducing ami using a propeller:
It seems very cool
SailorLiu is offline   Reply With Quote
Old   February 2, 2015, 07:10
Cool
Yuanchuan Liu
I have found a way myself.
1. Create a *.foam file inside every processor folder, e.g., processor0.foam in processor0 and processor1.foam in processor1 etc.
2. Open paraview and load each foam file into it.
3. Now you can colour every piece of the decomposed mesh using the coloring feature.
Hope someone likes it.
Old   January 3, 2019, 12:00
So Anon
redbullah is on a distinguished road
hello,
i am also trying to do the same thing.
i can load a *.foam file in paraview in decomposed state. is there any way of coloring each processor's block differently?
if not, is there an easy way of loading each processor*/*.foam file at once? like a script or something?
thanks
redbullah is offline   Reply With Quote
Old   January 8, 2019, 04:04
anonymous
simrego is on a distinguished road
Hi!
Try to use "decomposePar -cellDist"
This will write the cell distribution as a labelList. So if you open the reconstructed mesh (NOT THE DECOMPOSED!!), there will be a cellDist field which will indicate the proc number for every cell.
simrego is offline   Reply With Quote
Old   May 31, 2019, 02:26
raumpolizei is on a distinguished road
Hey there,
I had the same issue so I wrote a small utility that can be run in parallel on a decomposed case. It writes the procID as new field in the processor/time directories. The field can be reconstructed and visualized in paraview. Small changes may be needed as I am using OFv1612.
Cheers
RP
louisgag and aow like this.
raumpolizei is offline   Reply With Quote
Old   May 31, 2019, 04:55
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Thanks for sharing. Simple and useful. I got it running as is on OF-6-dev.
-Louis
PS: I've made a few changes to compile on v1812, did not dig into the explanations for them but it compiles and runs properly, see attached patch files.
File Type: patch options.patch (344 Bytes, 32 views)
File Type: patch writeProcIDAsField.C.patch (381 Bytes, 30 views)
aow likes this.
louisgag is offline   Reply With Quote
Moving mesh - Multiple Regions user10600 OpenFOAM Programming & Development 1 December 10, 2015 05:01
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
ParaView shows blocky mesh lfbarcelo OpenFOAM 3 June 25, 2010 08:16
