[OpenFOAM] Paraview Find Data
Old   March 14, 2018, 11:00
Default Paraview Find Data
Joaquín Neira
cojua8 is on a distinguished road
I'm trying to use the Find Data utility, but paraview shows this:
Error: Find Data requires that ParaView be built with Python enabled. To enable Python set the CMake flag 'PARAVIEW_ENABLE_PYTHON' to True.
is there any way to get rid of this or I should install paraview again as it says?. If so, how do I do that?
Thank you
cojua8 is offline   Reply With Quote
Old   March 15, 2018, 04:10
Hosein
einstein_zee is on a distinguished road
Thank you
Hi there,
Have you seen this thread already? "https://www.cfd-online.com/Forums/openfoam-installation/141505-python-not-enabled-parafoam-foamextend3-1-a.html" I didn't look thoroughly, but basically it addresses the same issue as you are addressing.
einstein_zee is offline   Reply With Quote
Old   March 19, 2018, 08:57
Joaquín Neira
I solved it by changing these lines in makeParaView:
withPYTHON=true
PYTHON_LIBRARY="/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0"
and the building again.
I used the location given by
locate libpython2.7.so.1.0
as the PYTHON_LIBRARY route, I don't know if you can use a different version of python.
I had to do this since the python building script didn't get the correct address
paraview, python
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times vidyadhar ParaView 9 May 20, 2020 20:06
Visualize Star-CCM+ data in Paraview peresah STAR-CCM+ 3 April 9, 2019 03:25
Generating binary data files in fortran to read in paraview nadeem_malik Main CFD Forum 6 May 24, 2017 07:47
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
[General] paraview - plotting difference to reference data joewe ParaView 0 August 30, 2010 18:01
