[OpenFOAM] How to tell paraFoam what data to use |
February 13, 2009, 17:05 |
BastiL
Rep Power: 20 |
I have a minor problem I could not solve so far. Running paraFiew from a OF case for me always reads the data from the 0/ directory. However I want to read the last time. There is no option like -lastTime, so how can this be done.
Regards BastiL |
February 13, 2009, 19:19 |
Hi Bastil
OF will rea
Hi Bastil
OF will read all the data at different time. If you want to see data at the final time, just change into the last time point using the animation button. If you don't want load other time point data, delete it or move to other directory. Junwei |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
[General] Advice on post processing compressor blade data in paraview | Jack001 | ParaView | 0 | February 4, 2016 17:16 |
redistributeMeshPar with scotch fails | matteoL | OpenFOAM Pre-Processing | 0 | March 30, 2015 11:13 |
How to setup a simple OpenFOAM cluster? | TommiPLaiho | OpenFOAM Installation | 3 | October 27, 2013 15:15 |
[OpenFOAM] Multiple independant data sets in paraFoam | christian | ParaView | 1 | August 27, 2007 12:30 |
