[OpenFOAM] Paraview cannot startup
Old   April 11, 2007, 13:35
Default Paraview cannot startup
Dean Wang
gnom is on a distinguished road
On my local PC I am using Xterm (exceed) to connet to the linux server on which the openFOAM is installed. But when I type the conmand "paraview", the paraview windown does not open up, and the error message says "Xlib: Extension "GLX" missing on display "192.168.0.170:0.0".
Please help. Thanks
gnom is offline   Reply With Quote
Old   June 8, 2007, 08:32
Default You need to update the driver
MK_MAT
mardit is on a distinguished road
You need to update the driver of your graphic card - if it is NVIDIA go to the website download latest driver, follow instruction to install and it should work.
I had the same problem.
mardit is offline   Reply With Quote
Old   October 7, 2009, 00:30
Scott
scottneh is on a distinguished road
I have been experiencing the same problem but I have the lates nvidia drivers and have loaded the glx module in xorg.com but still get the same error. Any other ideas? Could some libray file be pointing to the wrong location for the OpenGL drivers?
Thanks
Scott
scottneh is offline   Reply With Quote
Old   October 8, 2009, 05:11
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Does 'glxgears' show up an animation?
I have had various problems with paraView on different machines, and I find the best way is just to compile it from scratch. Your problem could be related to a number of things. What steps have you taken?
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   October 9, 2009, 13:02
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Gnom,
A number of guys in my research group have similar errors connecting (using xterm) to our linux server. Yet the guys in the room using Mac don't have this problem. The work around the windows' guys do is:
they install paraview for windows on their windows machine (obviously ), and then run foamToVTK and use scp/sftp to transfer the VTK files to their windows machine for post-processing with paraview.
It's a bit annoying but if you use a gui scp/sftp program like winscp (http://winscp.net/eng/index.php) then it's fine.
Luckily I use Mac and don't have this problem, but this is a handy work-around.
This does not solve your problem but gets around it, as Laurence said the problem could be related to many different things.
Hope it helps,
Philip C
bigphil is offline   Reply With Quote
Old   October 9, 2009, 13:43
Scott
I'm currently working this issue in Gentoo Linux on another forum and it has to do with the GLX module not being loaded properly due to an nVidia driver mismatch. I suspect that this is an nVidia issue and not a GLX or Paraview issue.
I'll post a complete solution and steps on how to resolve it a a few days once I have it worked out on my end
Old   October 14, 2009, 00:30
Scott
ok so here is what I have found. I am using an ASUS board with an nVidia graphics card and running Gentoo linux.
This issue comes from using the "nv" drivers under the Module section in the Xorg.conf file which defines how your desktop is laid out. The "nv" drivers do not have any 3D accelration and will not load the GLX module. To correct this you need to make sure you have the latest nVidia drivers installed and replace "nv" with "nvidia" in your Xorg.conf file. Also you need to add Load "glx" in the Module section. I do not have the latest drivers so I am having to work out a low resolution issuse. Check your version of linux to see what file you have to define the desktop layout and make sure you have the closed source nVidia drivers. Everything should work after that.
[General] ParaView startup Lucas_Gasparino ParaView 0 August 15, 2017 21:22
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release FJSJ OpenFOAM Installation 2 July 23, 2017 05:48
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 13:24
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 02:32
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
