[OpenFOAM] Visualizing Lagragian
Old   March 28, 2011, 13:15
Default Visualizing Lagragian
Prashant Gupta
Prash is on a distinguished road
Hi people ,
I am fairly new to OpenFoam and ParaFoam,
I wanted to visualize lagrangian particles.
After digging in a little I found to first run utility FoamToVTK in the case directory. But While I run I get a error . Here I copy paste whole of the output
Create mesh for time = 0
At time: 0.001 detected cloud directory : "defaultCloud"
Time: 0
volScalarFields : alpha p k epsilon
volVectorFields : Ua Ub
Internal : "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/mono1.5mmPeak-1.7.x-sample_0.vtk"
Original cells:540 points:1184 Additional cells:0 additional points:0
Patch : "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/inlet/inlet_0.vtk"
Patch : "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/outlet/outlet_0.vtk"
Patch : "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/walls/walls_0.vtk"
Patch : "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/defaultFaces/defaultFaces_0.vtk"
Lagrangian: "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/lagrangian/defaultCloud/defaultCloud_0.vtk"
Time: 0.001
volScalarFields : alpha p k nutb epsilon
volVectorFields : Ur Ub U Ua Uc
Internal : "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/mono1.5mmPeak-1.7.x-sample_5.vtk"
Patch : "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/inlet/inlet_5.vtk"
Patch : "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/outlet/outlet_5.vtk"
Patch : "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/walls/walls_5.vtk"
Patch : "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/defaultFaces/defaultFaces_5.vtk"
Lagrangian: "/home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/VTK/lagrangian/defaultCloud/defaultCloud_5.vtk"
labels : origId origProcId tag
scalars : d
vectors : U positions
spherical tensors :
symm tensors :
tensors :
--> FOAM FATAL IO ERROR:
wrong token type - expected int found on line 22 the punctuation token '('
file: /home_g07/s1065046/OpenFOAM/s1065046-1.7.1/run/mono1.5mmPeak-1.7.x-sample/mono1.5mmPeak-1.7.x-sample/0.001/lagrangian/defaultCloud/positions at line 22.
From function operator>>(Istream&, int&)
in file primitives/ints/int/intIO.C at line 68.
I am not sure how to go about this, Please help
Best Wishes
Prashant
Prash is offline   Reply With Quote
[OpenFOAM] Visualizing faces of an OpenFOAM mesh by ID in Paraview Timm Feigel ParaView 3 April 30, 2020 05:19
Rothalpy good for visualizing losses? eRzBeNgEl Lounge 0 August 12, 2011 04:40
[OpenFOAM] Visualizing in Paraview Kvadar ParaView 5 July 25, 2011 03:36
visualizing control volumes (not elements) dvolkind ANSYS Meshing & Geometry 0 March 24, 2010 10:40
Lagragian Suwinee CFX 4 July 18, 2001 03:28
