[OpenFOAM] Species mass flow rate
Like Tree2Likes
  • 1 Post By tomf
  • 1 Post By tomf
Old   April 19, 2011, 15:03
Default Species mass flow rate
N. A.
N. A. is on a distinguished road
Hello All,
I am trying to calculate the average mass flow rate of a particular species passing through a plane in the geometry, such as mass flow rate of CO2 passing through a plane.
Can you please let me know if know how we can extract this information in paraview.
Is there a way to calcualte this value directly in OpenFOAM
Thanks,
Nir
N. A. is offline   Reply With Quote
Old   November 14, 2012, 18:16
Tobi's Avatar
Tobias Holzmann
your post is old and you just made four posts so I think none will answer me.
Do you find out how that works?
If someone can explain it, it would be very good for me and all the others
Tobi
Old   November 15, 2012, 04:16
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hello Tobi,
How are you?
I think I may be able to help you on this one. The most easy way to do this with paraView would be to calculate the total mass flow through a plane using Y_CO2*rho*U_n where U_n is the velocity component normal to the plane of interest and Y_CO2 is the mass fraction of CO2. If you have a plane not aligned with x, y or z, you can use the calculator filter or the surface flow filter to get the velocity components perpendicular to that plane. Make sure the calculator for rho*U_n works on the cell data. Than go to filters>integrate Variables and you will get a table with the integral Y_CO2*rho*U*dA over Area A. This is the mass of CO2 passing through the area.
I do not have an example for doing this during the calculation, but I think something can be done with swak4Foam.
Regards,
Tom
kostnermo likes this.
tomf is offline   Reply With Quote
Old   November 15, 2012, 11:48
Tobi's Avatar
Tobias Holzmann
Originally Posted by tomf View Post
Hello Tobi,
How are you?
Regards,
Tom
Hi Tom,
I am fine. I have two weeks left to finish my masterthesis. Did you follow the libOpenSmoke thread? I find some fatal bugs in the tool and will bring out my updated model after I finished my thesis. So I think in 4 Weeks everything is avaiable (maybe + validation and description). To tool is very nice but there are some problems with the enthalpie. But I solved it
Thanks for your replay. I am too stupid
But I test it in the thermolibrary. therefor I ll create a new scalarField and will calculate the CO-emission in PPM directly. I think it should be possible and then I can compare it.
Tobi
Old   November 16, 2012, 03:32
Tom Fahner
Hi Tobi,
Yes I did follow the libOpenSmoke thread, looks like you have some interesting results!
Sounds like a plan,
good luck
Tom
Old   November 16, 2012, 06:46
Tobi's Avatar
Tobias Holzmann
Hi Tom,
one question to you.
If I want the massweighted species in the whole fluid domain, is it possible to do like you said with mag(U) then?
Old   November 16, 2012, 09:54
Tobi's Avatar
Tobias Holzmann
Hi Tom,
just one question, if I make everything correct.
I wanna calculate CO in ppm on a patch.
Therefor I calculate the Mean molmass with:
M_aver = sum(Y_i / M_i) of CO, O2, H2O, N2, CO2, H2, OH
After that I calculate CO in ppm like:
COppm = M_aver/M_CO * Y_CO * 1.000.000
Well the temperature profil looks better with OpenFOAM compared with ansys but if I look to the CO emissions there is so a huge difference:
Measurement 80 ppm
Ansys 60 ppm
OF 0.0013 ppm
I am not sure if I make everything correct!
Old   November 19, 2012, 05:53
Tom Fahner
Originally Posted by Tobi View Post
Hi Tom,
Measurement 80 ppm
Ansys 60 ppm
OF 0.0013 ppm
Hi Tobi,
I would think you have:
M_aver = sum(Y_i * M_i)/sum (Y_i) = sum(Y_i * M_i)
and I agree with your calculation of COppm.
Regards,
Tom
rksopenfoam likes this.
Old   November 19, 2012, 07:11
Tobi's Avatar
Tobias Holzmann
Hi Tobi,
Regards,
Tom
Hi Tom,
thanks for your replay.
I made a validation of my COppm calculation like I mentioned in the last post and its correct, like you told me
In that case I realized a other bug in the thermodynamics
but in my thesis there is no time for it. Maybe its a problem with the flameletgeneration.
Tobi
Old   December 3, 2012, 17:45
Wouter van der Meer
wouter is on a distinguished road
Maybe a stupid thing to ask someone that is working on a thesis, but is ppm for gasses not volume based instead of mass based?
best regards
Wouter
wouter is offline   Reply With Quote
Old   December 3, 2012, 18:29
Tobi's Avatar
Tobias Holzmann
best regards
Wouter
ppm on (maybe) the species CO is based on the mol fraction [X_CO] * 1.000.000 = CO_ppm.
If you wanna get an information on a slice its better to make a mass weighted calculation to get the better result.
If you wanna get an information on a specified volume you should do a volume weighted calculation.
If I am wrong please correct me.
Greetings Tobi
Old   January 20, 2016, 12:03
Thomas Oliveira
t.oliveira is on a distinguished road
Originally Posted by N. A. View Post
calculate the average mass flow rate of a particular species passing through a plane in the geometry [...] Is there a way to calculate this value directly in OpenFOAM
I had a similar problem (integrate a variable over an internal plane) and managed to do so. Please refer to http://www.cfd-online.com/Forums/ope...tml#post581774 . You may have to use areaNormalAverage instead of areaNormalIntegrate.
Best wishes,
Thomas
t.oliveira is offline   Reply With Quote
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 06:00
Shape Optimization Problem of Mass Flow Rate ggc1991 SU2 Shape Design 1 December 1, 2016 20:24
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
DPM total mass flow rate yow FLUENT 0 July 17, 2015 12:01
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 13:14
