[OpenFOAM] Rotating Axisymmetric Data in OpenFOAM/Paraview |
November 18, 2011, 11:24 |
Eric M. Tridas
Hey Foamers,
I've run an axisymmetric case of a jet into a vacuum chamber. I plan to take this data and couple it with an electrodynamic model in SIMION to calculate forces on flying ions. The data needs to be in Cartesian coordinates to import properly. I was wondering if there was either a utility for OpenFOAM or a function/filter in Paraview to rotate my data. Any help on this is appreciated. Thanks in advance! -Eric |
November 22, 2011, 18:46 |
Michael Ahlmann
If you convert the data to VTK you can import it into Visit (www.llnl.gov/visit) and it has a data rotation feature. Visit is developed by LLNL and it's also opensource.
November 23, 2011, 11:25 |
Eric M. Tridas
I actually found the feature in Paraview, its the rotational extrude (you must first take a slice though which is where I was running into issues). Unfortunately it only allows extrusion around the z-axis (which is not the axis I want to rotate it around). Thanks to danishdude though I will try and rotate the data itself so I can do the extrude around the proper axis. Thanks for your replies.
-Eric |
February 7, 2017, 08:28 |
Rep Power: 10 |
Don't know if this is still relevant for you. But one thing you cold do is to use Transform first (and rotate it to the proper axis), then use the Rotational Extrude.
February 13, 2018, 03:30 |
toto
You may use the transform filter in paraview.
Cheers, |
August 20, 2019, 08:27 |
Rep Power: 9 |
Hi! I've done the Reflect filter but when I slice my geometry and its reflection, there is a white line along the whole axis of reflection. How can this be removed?
Thanks in advance |
【Help】"Error: Update_Time_Level: invalid data" | Chen | FLUENT | 2 | August 24, 2014 07:51 |
Rotating tank problem using interFoam and an axisymmetric model | Krishna Sandeep | OpenFOAM | 0 | July 3, 2012 04:10 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 01:24 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
