a basic air ventilating(exhaust) problem
Old   December 5, 2014, 15:32
Post a basic air ventilating(exhaust) problem
incememed is on a distinguished road
Hello dear cfd online folks
I am a mechanical engineer student who should finish his project very soon. One part of my project is analyze the technical drawing which is related to project and get the velocity analysis. It seems that i am lack of knowledge when the case is 3d geometry. So i made some simplification about geometry
Basically i design a unit volume and put two outlet which should suck 5m/s of air from the unit volume and throw it to atmosphere from roof. Thats all i need. So i put them upper side of my unit volume(that is also represent my roof boundary) and start solver but i couldnt get a reasonable solution at all. I both try outlet type and fan type for my air hole and they do not help.
I am open for any suggestion. I use "phoenics". Best regards.
incememed is offline   Reply With Quote
Old   December 9, 2014, 09:40
Roman Gobitz-Pfeifer
Wikie is on a distinguished road
hello incememed,
do you want to create a vacuum? Two outlets and no inlet won't work. You need at least one additional inlet or opening in your room as well. Before starting your simulation you should check your mass balance by a quick hand calculation.
cheers wikie
Wikie is offline   Reply With Quote
Old   May 5, 2015, 05:15
MarkoP is on a distinguished road
I have a similar problem. I should simulate flow through 6 boxes stacked upon each other and have an outlet at the top, like a chimney or exhaust. I set 0 relative pressure at the opening of the boxes and a speed at the outlet, the exhaust, but I get that the air only passes through the top boxes.
You can see what the system looks like in the attachment.
Thanks
MarkoP is offline   Reply With Quote
Old   May 5, 2015, 05:28
Actually, here is the attachment,
Old   May 6, 2015, 02:34
Hi Marko,
is your question a general problem with the model setup or a software related problem - I'm asking because your posting an ANSYS screenshot in the phoenics section
cheers
wikie
Old   May 6, 2015, 03:48
Actually it should have been CFX but I haven't notices I'm on Phoenics forum. In any case it is a setup problem. I should model some flow resistance but I don't see how...
air flow, air flow simulation, exhaust gas, phoenics vr
Flow is not converging in natural convection problem of boussinesq model for air rahulsharma FLUENT 4 December 2, 2020 21:07
oil aeration problem wprostaff FLUENT 0 July 19, 2011 15:41
problem is modeling and simulation of an air foil alnabhani CFX 4 December 2, 2010 13:24
basic conduction problem for new user uncle_salty FLUENT 0 October 9, 2009 17:07
rectangular elbow air duct problem tony FLUENT 2 August 20, 2006 19:07
