About PRNDTL of temperature
Old   February 25, 2001, 08:11
Default About PRNDTL of temperature
H.P.LIU
In POLIS, Phoenics has provided the following information: PRNDTL(phi).... if positive, sets the laminar Prandtl number of variable phi. If it is negative, but not equal to GRND, GRND1, etc, the LAMINAR DIFFUSIVITY of variable phi is set equal to ABS(PRNDTL(phi)), with dimensions: length**2/time. For TEM1 andTEM2, negative values denote conductivities. When Temperature is represented by the solved-for variables TEM1 and TEM2 and PRNDTL(TEM1) is set for negative values, PRNDTL(TEM1) denotes heat conductivity ( Standard Unit: W/m/K),but as above mentioned, it also stands for heat diffusivity (Standard Unit: m**2/s), why has it different concept and unit when the same negative PRNDTL(TEM1) is set? How does PHOENICS formulate the energy equation in terms of temperature rather than enthalpy when the variable TEM1 is a solved-for variable? Thank you for your kind help!
static temperature more than total temperature ?? mahesh FLUENT 4 May 18, 2016 06:09
static temperature and total temperature showwa FLUENT 3 March 24, 2016 05:58
inlet temperature = outlet temperature Thierry FLUENT 4 March 17, 2006 10:14
Radiation temperature and Mean radiant temperature Arnold FLUENT 0 March 16, 2006 05:35
PRNDTL & PRT enhui Phoenics 0 November 23, 2001 02:59
