heat extraction
Old   November 14, 2002, 07:28
Default heat extraction
M. Pijnenborg
Hi folks,
I would like to implement a negative heat flux into my model. So far I have done several test with a blockage domain fluid and a plate. For both cases negative and positive heat fluxes are tested, none of the cases showed any effects. I am using the Extended Simple Chemical Reacting System (7-gas model), this might influences the heat fluxes.
Anybody any suggestions???
Thanks,
Marc
Old   November 15, 2002, 08:00
Default Re: heat extraction
herve
hi,
First of all, try to isolate more closely the potential problem. The 7-gas issue is likely to be irrelevant
Therefore, I would recommend your to test your "negative heat flux" on a case with a constant-property-fluid material (air at 20°C for instance), on a geometry that you should keep as simple as possible (2D typically).
If the problem persues, then you'll be in a position of identyfing more precisely what goes wrong.
Yours,
H.
Old   November 17, 2002, 20:51
leonmills
Marc,
I use Pv3.4 with bloackages in the domain with a positive heat flux alot.
A few things that I use when toble shooting.
Check if the heat flux is set as per unit volume or by 'abosulte value' - tag in the vr editor setting (I think these are the words).
Try setting the heat flux to some mucher larger - 10 to 100 time what you are looking at. It may juct be that at the heat flux levels you are talking about are too small to have a significant impact on the model.
Hope this helps.
Leon
Old   November 18, 2002, 06:06
Mark Russell
Completely concur with the above posts.
To gain confidence with Phoenics, and indeed any CFD, test the configuration in stages. Set up a simplified case that allows you to see if you have implemented the conditions correctly. In addition to the '2d' and 'large value' suggestions you could also try to solve a diffusion only problem - that way you should be able to see the heat being drawn into the heat sink from the rest of the material. It might be, as implied, that the value of heat sink is so small that convection effects are dominating and that you simply cant see it.
Hoping that this helps and that 'grandmother and eggs' doesn't spring to mind.
Mark Russell
How to model heat extraction device? i.e CRAC Unit laisquared FLUENT 0 January 1, 2009 23:07
FX Feature Extraction bastil OpenFOAM Post-Processing 3 December 15, 2008 09:18
VELOCITY TIME_SERIES EXTRACTION ANASTASIOS GEORGOULAS FLUENT 0 July 10, 2007 07:03
[OpenFOAM] Data extraction xy plot atzaru ParaView 3 January 28, 2006 17:18
Data extraction Renaud CFX 0 February 4, 2003 06:04
