why can not i see the output file?
Old   December 30, 2003, 02:31
Default why can not i see the output file?
macro
What i am dealing with is the transient problem. In the field dumping settings ,i set the first step ,the last step and the frequency. But why i can not see the output file in the d_priv1 folder?
Old   January 2, 2004, 10:25
Default Re: why can not i see the output file?
another
The PHI files at the intermediate time steps should be dumped if the start letter for PHI files is defined via CSG1 underthe 'field dumping' settings.
The field values will be printed to the RESULT file only if NTPRIN is set to the required step frequency under the 'field output' settings.
Output.fla File Morshed Main CFD Forum 0 February 12, 2009 20:00
Output file as Input file Waseem Siddique Main CFD Forum 0 January 7, 2009 09:42
output file Astrid FLUENT 1 June 19, 2006 16:01
[OpenFOAM] File output tj22 ParaView 1 May 19, 2006 04:22
OUTPUT FILE Sigmund CFX 1 November 12, 2001 19:27
