help !!!!variable output in cylindrical coordinate
Old   September 2, 2004, 07:57
Default help !!!!variable output in cylindrical coordinate
rohit
dear friends...
i am solving for potential distribution across a cylinder divided in three subregions..to set the properties in different region i have put such codings in lampr section
L0ELC=L0F(ANYZ(LBNAME('ELCO'),IZ))
DO IY=1,NY
ICELL=IY
IF(IZ.LE.10) THEN
F(L0ELC+ICELL)=3.0
ENDIF
IF(IZ.GT.10.AND.IZ.LE.20) THEN
F(L0ELC+ICELL)=0.00015
ENDIF
IF(IZ.GT.20) THEN
F(L0ELC+ICELL)=20.0
ENDIF
ENDDO
CALL FN0(LAMPR,LBNAME('ELCO'))
RETURN
previously i was using varyx commands(in case of cartes) to retrieve the data but now i want to write the values of variable(c1) in a file in the format used above..i tried but valuse are not the one which are there in result file .either i am unable to write iz slab wise values or u can help me out....
Old   September 2, 2004, 16:39
Default Re: help !!!!variable output in cylindrical coordi
mick
Just to try and open this question up a bit, as I dont completely understand.
Are you trying to set the Prandtl number/diffusivity for a variable you are solving C1 ?
Are you in ground Group 9 ?
I have never bumped into the variable ELCO, can you tell us what this is?
Old   September 3, 2004, 01:04
rohit
well thanks 4 ur reply..i am solving for a steady state potential distribution( cylindrical) by whole-field solver and have to set to properties for three different regions.so have to go into section 7 of group9 and set the laminar diffusivities of different regions .elco is defined by me to store the values of diffusive coefficient only..now as i run the programme i get correct distribution(values of c1) in result file but i want to write these in a file opened by user(me) ..or is there a way i can feed the laminar diffusivity coefficient in gr9 for cyl cordinate ...
Old   September 8, 2004, 21:28
Carlos
I am not sure if I understood your question, but if you want to write your own file, you may do like this: (1) Go to the ground section just after the sentence "end of time step" (I am not with PHOENICS here, so I do not know exactly the number of the group) (2) use a traditional fortran code to: - open a file - write your data at this file using your format choice (use a fortran do loop to choose the positions you want to print) - close the file (3) recompile your code and run (use private option) I may sent an example if you need.
Good luck!
cylindrical coordinate vs cartesian coordinate Lam FLUENT 10 May 11, 2013 13:05
cylindrical coordinate ammi FLUENT 3 March 2, 2007 10:07
I need help for cylindrical coordinate in LES Agus Main CFD Forum 1 October 23, 2003 09:09
FDM in Cylindrical Coordinate Piakman Main CFD Forum 8 November 26, 2001 10:14
cylindrical coordinate anjan chakraborty Main CFD Forum 1 December 10, 2000 22:41
