Species transport
Old   December 19, 2004, 01:42
Default Species transport
lin
Hi Everyone,
Who could help me about the species transport with Phoenics?
I try to calculate the species such as odors dispersion in a block. I do not know how to input the species parameters in the inlet with VR windows.
Thanks
Lin
Old   December 19, 2004, 01:45
Default Re: Species transport
lin
Old   December 19, 2004, 19:59
leon mills
Try setting the contaminant (C1) source in the inlet term. Set this with the density, concentration, and temperature as required.
C1 is set as a scalar so 100 could be 100 ppm or 100 ppb, just remember the sale used for the outputs.
There is a library case in the tutorials that looks a dispersion of fumes from a car park exhaust.
Hope this helps,
Leon
Old   December 20, 2004, 08:50
Hervé
Sorry if this reply is not fully appropriate. I am just concerned by the units inferred here. "PPM" and "PPB" refer to volumetric fractions (respectively "parts per millions", and "parts per billions", I assume).
I would have thought that unless a dedicated transport equation for volumetric quantities (i.e. with a specific additionnal source term), the default unboarded equation was recommended only for massic quantities. Therefore, C1 in kg/kg would be more suitable.
Indeed, once solved, C1 values can be converted, wia the density, to any of their counterparts volumetric quantities. In Phoenics, if not part of the core code, it can be easily done in storing for instance C1PM or C1PB and add the appropriate Fortran additional coding.
Hope it helps.
Old   December 20, 2004, 23:54
leon mills
Herve,
You are correct. I have set this up in my file and forgot that C1 should be represented in kg/kg or something similar then converted to ppm...
Leon
Species transport cristiano FLUENT 0 September 26, 2008 09:34
about species transport. shuqin FLUENT 4 March 16, 2006 21:57
2D vs 3D species transport? jdb FLUENT 3 July 7, 2005 07:26
species transport co2 FLUENT 0 May 12, 2005 21:32
3D species transport Fassika FLUENT 2 January 27, 2003 17:11
