June 9, 2005, 02:22 |
About Phoenics 3.5 & 3.6
I have 3.5.0 & 3.6.0 versions of Phoenics. Why my solution obtain the convergence in 3.5.0 but in 3.6.0 is not? May I ask - what version is "more right"?
June 11, 2005, 14:53 |
CHAM, where are you?
Phoenics 3.6. In-form formula (PROPERTY of PRNDTL(TEM1) is 40 with IMAT=111). As result conductivity is 20. Why?
June 16, 2005, 12:10 |
Re: CHAM, where are you?
If you are a supported user send it in to support.
These are the type of problems that can take ages to resolve. Partly because users have such large grids. You could investigate this yourself if you are systematic I would advise 1/ reducing mesh density 2/ simplifying problem until results match 3/ Can try and switch off PARSOL see if this makes a difference 4/ make sure you compare results on convergence. |
June 16, 2005, 16:04 |
Thank you Mick. But you advise me to solve my problem again. I have no time to reducing mesh density (and i cann't understand why, if i have phi file from ver 3.5)... I try to simplifying my problem and switch off PARSOL (my problem hasn't partial solids) - it cann't helps... I think - problem in k-e model in ver. 3.6.0. And what you can saying about INFORM question?
June 17, 2005, 08:24 |
Hi Timur, about the convergence problem Its impossible to say without examining your case, however a lot of improvements and fixes have been made to v3.6. I would examine the RESULT file for each case and look for any differences. It might be that some default setting has changed. Alternatively, if it deoes not diverge wildly, perhaps its just a matter of a small change to the relaxation settings.
about the inform.. I have just had a look at POLIS and I believe that to set the conductivity using PRNDTL and inform inform9begin (property of PRNDTL(TEM1) is 400 with IMAT=111) inform9end should work, it does with the latest v6.0 that I am using. If it does not work a way around is to edit the props file for material 111 and change the conductivity. mick |
June 17, 2005, 09:44 |
Thanks Mick. I can send you my q1 and phi files if you have the time. I have ver. 8.3.2.4 of INFORM. Unfortunately in props file I cann't set conductivity which depends of temperuture (there is no GRNDX for conductivity). I also can send you another q1 file.
phoenics | Trushar | Phoenics | 7 | August 5, 2011 15:34 |
new to CFD using Phoenics | New | Phoenics | 5 | July 9, 2006 13:03 |
Phoenics 3.2VR | SAIF | Phoenics | 1 | October 6, 2000 10:48 |
PHOENICS 3.2 VR | Saif | Main CFD Forum | 1 | July 4, 2000 05:12 |
PHOENICS | Vijay Thaker | Main CFD Forum | 2 | August 28, 1998 10:20 |
