why this boundary condition works?
Old   November 24, 2005, 23:03
Default why this boundary condition works?
manish
I have read manual that when we apply mass flow or velocity at inlet and pressure at outlet then it will more robust.but when we apply pressure at inlet and velocity at outlet it will diverge the solution.The later is applicable only to compressible flow.Can anybody tell me why this is happening? the outlet mass flow is applicable to fully developed flow.so what is fully developed flow? and why it is robust for outer mass flow? Thanx
Old   November 30, 2005, 05:20
Default Re: why this boundary condition works?
mike
The solution algorithm is more stable numerically when the pressure is fixed at the outlet, and the mass inflow rate is prescribed at the inlet. If the boundary conditions are reversed as you describe, then I do not think that divergence will necessarily result. It should be possible to acheieve convergence, although the prescription of a uniform mass outflow rate may not necessarily be realistic on physical grounds.
I don't really understand the comment "The later is applicable only to compressible flow.", and hence the remainder of your questions are rather unclear. If you can say where this statement appears, and in which manual, I may be able to provide some explanation.
why this boundary condition works? manish Fidelity CFD 1 January 4, 2006 03:27
why this boundary condition works? manish CFX 0 December 7, 2005 07:06
why this boundary condition works? manish Siemens 4 November 27, 2005 09:00
why this boundary condition works? manish Main CFD Forum 1 November 26, 2005 14:22
why this type of boundary condition works? manish CFX 0 November 24, 2005 23:00
