optimal probe position for convergence
Old   July 12, 2010, 09:54
Default optimal probe position for convergence
Gai Abraham
ga5aq is on a distinguished road
Send a message via Skype™ to ga5aq
Hi all
following from my previous thread (drag calibration of cube) does anyone know if convergence can be reached while the probe is within a turbulence area behind a Cube (in my case)?
As it doesn't seem to converge after a day's iteration
any views will be greatly appreciated
G
ga5aq is offline   Reply With Quote
Old   April 12, 2011, 17:29
Nathan
Welshnathan is on a distinguished road
Hi ga5aq,
What is your global convergence criterion set at?
I was not aware that the probe position would impact the speed of convergence? If this is the case, I would not recommend placing it in the turbulent region.
Have you tried feeding your variable values obtained in a given run, back into a new run?
This can be done at the initialisation section. The following has been taken from the PHOENICS help documentation (POLIS):
'If one knew the solutions to the equations at the start, and could insert the corresponding variable-field values as initial guesses, convergence would be immediate. Of course, the solutions never are known; however, if initial guesses can be made which are close to these solutions, convergence is likely to be rapid.'
This should save you some time instead of waiting for 12 hours to reach the same level of convergence every run.
Also, check out the Polis section on convergence:
http://www.cham.co.uk/phoenics/d_pol...nc/converg.htm
Hope this helps.
Welshnathan is offline   Reply With Quote
Using Probe for part of a patch ndr OpenFOAM Running, Solving & CFD 7 April 4, 2019 06:26
create a probe with fluent Aenseeiht FLUENT 3 April 29, 2010 03:27
determine face position Ralf Schmidt FLUENT 1 April 24, 2009 09:37
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
