August 27, 2015, 07:59 |
change coordinate in Pointwise
Rep Power: 11 |
Hi everyone!
I have a 2d mesh in pointwise in xz plane, I want to change it into XY plane and input into Fluent, can anybody help me how to do this? Thank you so much |
August 28, 2015, 10:34 |
David Garlisch
Location: Fidelity Pointwise, Cadence Design Systems (Fort Worth, Texas Office)
Select all the domains
Use Edit / Transform / Rotate... menu Angle -90 Select Point and Direction XYZ: 0 0 0 (or other appropriate point) Select a Direction X OK |
[Commercial meshers] Pointwise to Foam - cyclic BC points order | Pj. | OpenFOAM Meshing & Mesh Conversion | 5 | August 14, 2016 04:47 |
Build Topology in Pointwise & Local Surface Refinement | nnprashant | Pointwise & Gridgen | 1 | August 25, 2014 09:26 |
[DesignModeler] change the global coordinate | swiss_zhang | ANSYS Meshing & Geometry | 0 | June 28, 2011 02:58 |
change coordinate system | Nabil | FLUENT | 2 | February 12, 2010 11:23 |
change coordinate system cartesian to cylindrical | tht | FLUENT | 0 | September 6, 2007 05:46 |
