November 18, 2021, 02:53 |
Roughness on solids
Felix S.
Rep Power: 6 |
Hey everyone,
I just wanted to ask what roughness is applied to the wall functions of an added solid. If I want to use separate roughness coefficients on different boundaries what roughness is chosen for the solid. If I for example use: B 52 0.01 B 53 0.05 B 55 0.001 in a rectangular flume and have a solid object in the middle of a rectangular channel which roughness will be applied? How is this determined? Is there roughness at all on solid objects? Is the roughness on a solid object set to the global roughness, while the boundary roughness can be overwritten? Many thanks in advance! Last edited by Felix_Sp; November 18, 2021 at 04:04. |
November 18, 2021, 09:46 |
Hans Bihs
Rep Power: 18 |
Hi Felix,
right now, solids use the B 50. To be able to assign different roughnesses on different solids is on my todo-list |
November 18, 2021, 10:19 |
Felix S.
Rep Power: 6 |
Thanks for the quick reply!
Does that mean that I can set a roughness to all solids with B 50 and different roughness coefficients to the boundaries (e.g. with B 52 and B53)? Or are they being overwritten by B 50? |
November 18, 2021, 10:41 |
Arun Kamath
You are correct.
B 50 is the global wall roughness and will be applied everywhere in the domain. B 51-54 will overwrite that, but only for the specific wall that the option refers to. So, in that way, yes, you will be able to set different roughness for the solids and the boundaries
Arun X years with REEF3D |
November 18, 2021, 10:44 |
Felix S.
Rep Power: 6 |
Thanks for the clarification!
nutRoughWallFunction and Surface Roughness Documented | AlanR | OpenFOAM Programming & Development | 64 | January 6, 2024 07:13 |
Surface Roughness Drag Analysis | shindiregita | FLUENT | 0 | May 30, 2020 02:32 |
Roughness effect | nasir.iitd | FLUENT | 0 | September 28, 2016 23:28 |
simulation of effect surface roughness on aifoil | kamyarmech | FLUENT | 1 | February 28, 2016 09:33 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
