negtive density
Old   December 18, 2000, 09:49
Default negtive density
zliu
Trying to run transient analysis, the run stop after
the first iter. message is like
STEP UVEL VVEL WVEL MASS T EN DISS ENTH U V W P TE ED T
1 1.93E-02 2.41E-05 6.43E-02-4.74E-02 9.69E-01 7.81E+03 1.36E+04 -1.86E+00-6.49E+00 1.63E+02 1.28E+03 2.24E+02 1.99E+06 6.02E+02 Warning - starwatch daemon is not registered, no information sent to starwatch.
*** ERROR #076 *** NEGATIVE DENSITIES FOUND AT MORE THAN 100 CELLS. RUN STOPPED
what wrong of my model set-up
Old   December 18, 2000, 10:04
Default Re: negtive density
Durstberger
Hi
Does your time step meet the courant equation?
(Cr = (v * t)/L ,where Cr = Courantnumber of a cell, v = velocity of fluid in this cell (compressible: velocity of fluid + speed of sound), t = time step and L is the length of this cell)
The max. Cr shouldn't exceed 50 - 100.
Old   December 20, 2000, 04:29
Ahmed Hassaneen
If you do have moving mesh (events module) you may try to reduce the time step length.
Old   December 20, 2000, 04:33
Ahmed Hassaneen
Another thing to you and to the others who has the same problem you may try the MARS differencing scheme and don't ask me why because I don't know why but it works.
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
mass density or weight density jaichan Main CFD Forum 0 April 2, 2006 18:45
density of NO2 and COS j Main CFD Forum 2 May 22, 2003 09:42
density of NO2 and COS j Siemens 0 May 21, 2003 05:12
how to set the density xqy Phoenics 3 January 20, 2003 06:06
