switches option
Old   August 1, 2001, 04:09
Default switches option
Sabatini
hay people
how i can use switches option the modified the relaxation factor during the calculation. thanks
Old   August 1, 2001, 11:09
Default Re: switches option
allan
enable switch 50
then write your problem file.
A file "casename".ctrl is created which contains the relaxation factors etc. This is visited every iteration this can be edited and therefore the relaxation factors can be changed easily.
allan
Old   August 3, 2001, 04:52
Sabatini
Hay Allan
i can do that during the calculation via starcd window or via unix schell
Tahnks
Old   August 8, 2001, 14:42
allan
you need to set this up before you write the problem file. You cannot initiate this after the calculations have started.
cheers
allan
Switches and Real Constants usker Siemens 2 March 30, 2007 04:18
Switches and Real Constants for Diesel Combustion Tony Siemens 0 July 30, 2006 20:15
Switches A.S. Siemens 2 May 29, 2005 20:02
Switches i other controls Mir Siemens 1 December 17, 2001 07:34
Star-CD Switches James Siemens 2 July 6, 2001 16:11
