Fix Mass/Vel. in BC
Old   January 29, 2002, 08:14
Default Fix Mass/Vel. in BC
Julie Polyakh
Hi!
What is the difference between Fixed Mass and Fixed Velocity Flow Swithches for Inlet BC?
Thanks,
Julie
Old   January 29, 2002, 09:04
Default Re: Fix Mass/Vel. in BC
stephen
If you have compressible flow, the density at the inlet will vary depending on the pressure field calculated as part of the solution.
If you choose a fixed velocity boundary condition then the velocity you specify will be applied at the inlet boundary. As the density at the inlet changes (in response to changes in the pressure field) then the mass flow through the boundary will change.
If you choose fixed mass, the density and velocity you specify will be used to calculate a mass flux. This mass flux will be applied at the inlet boundary, so that if the density at the boundary changes, the velocity at the boundary will change also.
Basically you have to choose one or the other, you obviously can't fix both the mass flow rate and the velocity if the density changes.
If your flow is incompressible then it doesn't matter which you choose.
Cheers
Stephen
Old   January 29, 2002, 09:23
Julie Polyakh
Thank you, Stephen!
Old   February 14, 2002, 04:43
Vladimir Krejci
Hi !
I would like to know how I can enter fix volume flux. I use negative inlet i.e. fluid is exhausted from a solution domain and I do not know what density is. This situation becomes when the fluid is multicomponent.
Any proposals?
Thanks
Vladimir
Old   February 15, 2002, 04:29
stephen
Vladimir,
If you are specifying a velocity over a fixed area (using a reverse inlet) you are fixing the volume flux....Qfix=UA.
The mass flow rate will vary as the density of the mixture changes (m=RHO*Qfix).
If you use a fixed flow outlet, then you will be specifying a mass flow rate (in kg/s) and the volumetric flowrate will vary as the density of the mixture changes Q=mfix/RHO
Make sense?
Stephen
Old   February 15, 2002, 09:49
Vladimir Krejci
Thank you for your answer.
If I understand, it does not matter what option I will use in this case?
Vladimir
Old   February 18, 2002, 10:49
nicola
Hi Vladimir,
as Stephen sais, it depends on the compressibility. If your media is incompressible, it does not matter what option you are using, but if it is compressible you should enter the volume flow = velocity.
reported mass flow differs from monitored mass flo London FLUENT 4 July 17, 2008 12:44
mass source and mass sink for multi-component frank CFX 0 May 14, 2008 11:55
Mass sink and mass source in eulerTwoPhase application newbee OpenFOAM Running, Solving & CFD 3 July 9, 2006 07:15
correct units of mass transfer used in mass intera prasanth FLUENT 0 June 2, 2003 12:11
How are the mass flux and mass flow rate defined? Miles Siemens 2 November 7, 2002 08:45
