February 6, 2002, 07:41 |
Windows or linux??
I am currently running star 3.100b on a dual p3 1ghz with 3gb of ram, what sort of preformance gains will i get if i use 3.15 on linux bearing in mind that this will enable me to use both of my processors with HPC?
February 6, 2002, 09:57 |
Re: Windows or linux??
I've seen around a 10-15% increase in speed just in going from windows to linux (less overhead). You will get a boost of anywhere from 50-100% by using 2 processors. On the other hand, 3.15 with HPC for windows will also be out shortly and you will be able to get the same boost without switching.
February 7, 2002, 08:14 |
cheers for that
Fluent - Linux vs Windows | derick | FLUENT | 2 | August 16, 2020 11:23 |
UDF error from Windows to Linux | manu | FLUENT | 3 | January 10, 2008 04:02 |
Linux or Windows? | lizhihua | Siemens | 5 | May 24, 2006 21:18 |
udf cannot run in windows but can in linux | ra shmi | FLUENT | 2 | February 14, 2006 12:12 |
.cas .dat Windows vs Linux | K. Jagus | FLUENT | 2 | August 9, 2005 13:58 |
