Turbulence model for land-scape?
Old   May 2, 2002, 06:06
Default Turbulence model for land-scape?
Anne Rasmussen
I am initiating a small research project conserning siting of wind turbines in complex landscape structures.
Does anyone have experience to share - choice and setup of turbulence model are of particular interest
/Anne
Old   May 2, 2002, 07:37
Default Re: Turbulence model for land-scape?
Jens Chr. Bennetsen
When simulating wind environment it is very important to have the right boundary layer profile together with the turbulent kinetic energy profile. And also surface roughness is important.
AS for the turbulence models, as long as you do not use standard k-eps. It works okay, but is know for its short comnings. I have often used RNG which I have proven to be quite good also when comparing to exsperimental data.
Also remember that termal effect can change the wind profile during the day. So if you have large termal gradient during the morning and afternoon, large differences can be seen.
Kind Regards
Jens
Old   May 2, 2002, 08:45
Anne Rasmussen
when using the RNG model are any of the coefficients in the model changed from the default values in order to maintain a sufficient kinetic energy level?
And is the model supplemented with a boundary model?
Sincerely Anne
Old   May 2, 2002, 08:53
Jens Chr. Bennetsen
Hi agian
No default values has been used. The MMK k-eps model could also be used.
Regards
Jens
Old   May 2, 2002, 09:04
Anne Rasmussen
do you mean "no default values" or " no - default values has been used" ?
Sincerely Anne
Old   May 2, 2002, 16:15
Jens Chr. Bennetsen
Yes
I have just used the default values for the RNG model.
The has been a lot of work done by Mochida and Murakami on wind engineering with different turbulence models.
Regards
Jens
changing model constants in k-e turbulence model Sunil CFX 3 October 3, 2006 12:12
cfd modelling of land mower ( Grass cutting machin Raj FLUENT 0 October 19, 2005 07:26
Turbulence model sam FLUENT 2 October 4, 2004 03:09
HELP! TURBULENCE k-e OR k-omega TURBULENCE MODEL? Mirek Kabacinski FLUENT 5 August 24, 2003 22:31
