ProSTAR in batch mode
Old   October 2, 2002, 06:46
Default ProSTAR in batch mode
roadracer
Hi everybody. I am able to run ProStar in batch mode, i.e. typing "prostar -b", but I have a problem: if I write "prostar -b glm" it jumps the request of the graphic device, but it asks the model name and I have to write it from the keyboard. How can I tell him to start automaticly with the case name that I want, without typing it on-line? I tried with "prostar -b glm casename" but doesn´t work. Any help apreciated
Cheers Roadracer
Old   October 2, 2002, 12:07
Default Re: ProSTAR in batch mode
Jiaying Xu
So, why not try I/O redirection or piped command?
Cheers,
Jiaying
Old   October 2, 2002, 13:59
Joern Beilke
pro-glm -batch < batchfile.inp > logfile.out
all plots are written to the neutral file case.plot or the file specified in the nfile command. You can not use the hardware accelerated open-gl functions during a batch run.Also scdu does not work.
You can also use the pro-xm or pro-x version of prostar. The result is the same.
pb with batch mode philippe FLUENT 2 October 21, 2008 17:39
Batch mode in WB. cfdguy CFX 1 June 24, 2008 06:49
Pre in batch mode Kuts CFX 7 August 17, 2007 05:10
Batch mode Achim Frahm Phoenics 0 July 25, 2003 12:14
Batch mode swapnil CFX 5 November 23, 2002 09:38
