Where is avaraged quantities in LES?
Old   October 28, 2002, 20:13
Default Where is avaraged quantities in LES?
Lesser
In LES simulation, lesout command is needed to obtain the avaraged quantities. I can understand it. But where are the result data stored?
Old   November 5, 2002, 09:58
Default Re: Where is avaraged quantities in LES?
Jamie
The average data are stored in the casename.lesc file.
To load the data, use the command
getu casename.lesc
Old   November 8, 2002, 11:11
TIM
You will also get a .lesr file which contains the average magnitude of the fluctuating components. This is the same format as the .lesc file and can be loaded with the getu command.
Old   November 12, 2002, 23:07
Lesser
Thank you for your response, Jamie and TIM, I can find .lesc but .lesr. Which version is it supported from? Or do I need additional setting?
Averaged quantities otrebla CFX 0 April 11, 2008 10:03
Dimensionless quantities badri1979 OpenFOAM Running, Solving & CFD 1 August 22, 2006 17:47
how to do the statistics of other quantities? lcw FLUENT 3 January 1, 2006 22:47
Time-averaged quantities david FLUENT 1 August 22, 2005 19:46
freestream quantities Sheila Siemens 4 September 28, 2004 02:17
