Heat flux on a irregular surface
Old   December 4, 2002, 05:35
Default Heat flux on a irregular surface
massimo
hello, In order to obtain the heat flux through the wall of the casing of machine at a given section, I should create a set of vertex on the exterior casing but the casing is not a regular circle.
I would create a set of vertex on a inner circle and then I would move them to the external casing. I can create the vertex set but I can't move them as I would like.
How can I get it?
Old   December 4, 2002, 20:11
Default Re: Heat flux on a irregular surface
raymond
Maybe you could generate shell for the exterior case, and then project the vertex onto the shell at prescribed direction.Hope it work.
Old   December 5, 2002, 03:33
massimo
Ok, I try to do it. Infact I generate shell with the command "pscreate" and I project the vertex with the command "Vproject", but after that the vertex set not lie on exterior casing (external surface). How is possible? Bye
Old   December 5, 2002, 09:20
massimo
Sorry but I made a mistake in the previouse message. How can I generate shell for the exterior case if the casing is not regular?
With the command "pscreate" I generate shells into normal section plane but not on the external surface as I need. In fact if I want to move the vertex set to the exterior casing from initial inner circle I must create shell around external surface.
How can I get it? Bye
Old   December 5, 2002, 22:02
raymond
First, I think you have the geometry of the whole case.(in fluid or solid format). Then you can create shell by the command "cfind" or CSET,NEWS,....(SELECT THE CELLS CONTAINS EXTERIOR CASE) VSET,NEWS,CSET,EDGE using the menu "tools ->cell tools" then select "add shells -> surface (new edge vertex set) you can create the shell of extrior case
Old   December 11, 2002, 05:55
massimo
Thank you for your help, now I can create the shells on the surface and I have found the heat flux through the wall, but it seems there is an error sign because the heat flux is positive where a great heat flux to the air, that is a negative flux, is expected. I have followed your hints: I projected (VPROJ) 72 vertices to the surface shell and I mapped (PMAP VSET CSET,,10) the heat flux values, obtaining the results i told you before. Can you suggest me how to solve this problem? Bye
Applying Heat Flux out of the surface in CFX Ijaz CFX 3 February 26, 2009 16:33
Total heat flux vs surface integral Al FLUENT 0 December 22, 2008 12:16
constant surface heat flux Andrew Hayes Main CFD Forum 4 March 16, 2006 07:19
surface heat flux joe Phoenics 1 November 30, 2005 05:34
Estimating Surface Heat Flux M.Lakshminarsimhan Phoenics 2 September 2, 2003 05:24
