Covert Star-CD model to FLUENT
Old   June 9, 2003, 14:22
Default Covert Star-CD model to FLUENT
Lam
Hi. I am a CFD beginner who will model turbulent flow using FLUENT from existing Star-CD model. Can I convert the Star-CD model directly and run the simulation in FLUENT package? Is there any functions or methods to do that? Or it is something not related completely between these two package? If you have any information or idea, please let me know. I appreciate your opinions. Thanks.
Old   June 10, 2003, 13:22
Default Re: Covert Star-CD model to FLUENT
Nameer Salman
yes, you could do that, you have to create domain file within prostar, then read in the domain file within ICEMCFD, and write out the .msh file to fluent from ICEMCFD. One thing that the above process is not direct, and you have to have ICEMCFD.
Old   June 11, 2003, 02:47
Paal
In the lower end of the NavCentre(StarGuide), there is a folder called export. In this folder you can export grid in various formats. Most codes, probably also FLUENT, can read the NASTRAN format. Note you will only get the grid, not the boundary conditions, thermo-physical set-up and so on (So you will have to redefine this.)
Best of luck,
Paal
Old   June 11, 2003, 02:48
Joern Beilke
It is easy as long as you dont have couples and trimmed celles.
Put shells with a unique cell type on every boundary region and export all in Nastran format.
Read the file into fluent (not GAMBIT !!!) and thats it.
Old   June 12, 2003, 05:43
Lam
Is that means I just can convert mesh from Star-CD to FLUENT and I have to redo the solver and postprocessing parts in FLUENT? Thanks for your opinions.
Lam
Old   June 13, 2003, 10:49
steve
Why would anyone ruin a perfectly good STAR model by running it in Fluent? The best you could hope for, if you are lucky, is an answer that is at least as good as STAR's (I suppose it is possible that I may be just a little biased).
The answer is - you do have to redo the set up, boundary condition values and post-processing to move to fluent or any other CFD program. This assumes that you actually can move the mesh since Fluent does not support as wide a variety of cell shapes as STAR does.
Old   June 24, 2003, 20:21
skipio
By the way if you are exporting nastran or patran or cgns from starcd to fluent 6 it will work on linux or unix but not on win2k or winXP because Fluent 6 under windows seems to have a bug. This is valid untill about March 2003 and i haven't got a clue if there was a patch for this problem.
CFM model in star-ccm+ sally Siemens 0 May 29, 2008 20:40
V2F model in Star-CD 3.24 Win DenizeN Siemens 3 October 19, 2005 02:32
STAR-LT radiation model saturn Siemens 1 April 21, 2005 23:19
Covert gambit file to polyflow file John FLUENT 5 August 6, 2004 08:31
