why did the message always come out?
Old   June 25, 2003, 18:49
Default why did the message always come out?
Lee
When I run a roundpipe model(which is a semi-circe,at one end of the pipe the bounday type is inlet,the other end is outlet,and there is a symmetry boundary),I set the outlet boundary as the prescribed flow split(fs=1),but the information file always shows one warning message:
*** WARNING #001 *** FLUID INFLOW DETECTED AT SOME OUTFLOW BOUNDARIES WHERE MASS FLUXES ARE FORCED TO ZERO.
IF THIS CONDITION PERSISTS, YOUR RESULTS MIGHT BE WRONG
THE OUTFLOW BOUNDARY MIGHT NOT BE WELL SPECIFIED OR THE GRID MIGHT BE TOO COARSE NEAR THE OUTFLOW BOUNDARY
but I think I the meshs created are enough fine,so what is the reason to cause this warning message?
Thank you very much for your help!
Best Regards, Lee
Old   June 26, 2003, 07:37
Default Re: why did the message always come out?
4xF
You get back flow at the outlet boundary. Solution: Use a pressure boundary instead.
Old   June 26, 2003, 08:24
Lee
First,thank you very much! Second,I just want to know why the warning message always comes out and what is the proble reason to cause the problem.
I think if the model simply like this one can't be modeled by the inlet and outlet boundary type(note,the inlet flow velocity is 50+20*sin(time),and diameter is 38 milimeters),how can the star-cd model the other complex models?
So I really want to know where the problem is.
Thanks a lot for who can help me out this problem!
lee
Old   June 27, 2003, 04:48
marco
Hallo!
If you are doing a subsonic transient calculation you shouldn't use 'OUTLET' but 'PRESSURE'. Look at the methodology manual, page 5-5.
Marco
Old   June 28, 2003, 09:58
4xF
Small hint: Flow is unsteady with an unsteady boundary layer. So, it is most likely that you get back flow at the outlet and therefore a pressure boundary condition has to be applied instead of an outlet BC.
I got "Error Message" Young CFX 0 April 25, 2008 13:00
Error message mbouda FLUENT 0 July 16, 2007 04:45
What is this message? David Baker Siemens 0 March 14, 2006 01:02
Error message Luc FLUENT 1 December 12, 2002 14:22
What does this message mean? Marc FLUENT 0 November 14, 2001 12:45
