Coupling problems II Fixed
Old   July 16, 2003, 06:29
Default Coupling problems II Fixed
Julie Polyakh
After fixing the problem with collapsed faces the following problems are still present:
1) Cell face is in two or more couples with different couple types;
2) Cell in couple is undefined (still;
3) Cells found with negative volume or volume less than specified value.
The first and the last messages I like least of all.
Julie
Old   July 16, 2003, 21:21
Default Re: Coupling problems II Fixed
Not_even_close
1. can one cell face be coupled with another cell face in two different ways at the same time ? 2. if the cells are not defined, you dont need the couples. 3. are they tirmmed cells or skewed hex cells ?if so, they have to fix them manually.
Old   July 17, 2003, 02:27
Julie Polyakh
OK. Thanks to overall help I've fixed all the errors and... got an error that I've fixed already 3 times at least. It claims that I have couple with partial boundaries turned on that contains both fluid and solid cells. I know exactly that I created these couples as arbitrary with partial boundary turned off. It's just impossible!
Julie
Old   July 18, 2003, 07:50
No_even _close
do this:
cset,news,solid$cpset,news,cset,any$cpdel,cpset$
this will remove all the couples attacthed to the solid.
Old   July 18, 2003, 09:06
Julie Polyakh
But I need these couples...
Old   July 18, 2003, 10:39
Thomas
Julie,
the problem is, star-cd cannot deal with partial boundaries between solids and fluids. but you can only turn off the partial boundary-flag if the faces between solids and fluids are of the same size plus/minus a certain tolerance. if the difference is too high prostar gives you an error-message. the only way to avoid is to ensure a matching of the cell face areas or to leave these regions uncoupled!
thomas
What is weakstrong coupling in FSI problems hajo OpenFOAM Running, Solving & CFD 5 May 15, 2008 01:45
fixed conc. B C umesh FLUENT 5 September 2, 2003 20:24
Coupling problems Julie Polyakh Siemens 8 July 17, 2003 02:27
fixed pressure alex Phoenics 6 October 6, 2001 11:29
fixed bed combustion Adi FLUENT 7 April 19, 2001 01:20
