baffle in use
Old   November 7, 2003, 00:24
Default baffle in use
guang ai
I have a problem with using baffle. I run a problem with a baffle put in nearly half of the path. It was keeping diverged in less than 200 iteration no matter what a relaxation I selected, such as R for press < 0.05. Once I switch the fluid adjecent to baffle to solid, calculation converged to -3 order of magnitude in mass. Does anyone have similar problem before or any suggestion, I will feel very grateful.
Old   November 7, 2003, 13:27
Default Re: baffle in use
Marc
Is your flow domain completely separated by the baffles? That would imply that they are permeable baffles. In that case: Start with a low pressure loss over the baffles and restart with higher ones, until you reach your desired value.
Hope that helps, Marc
Old   November 9, 2003, 19:14
guang ai
thank you for your response. my case is not that complicated as you guessed, with only mesh seems complex. it is a problem with flow bifurcated for a distance and merged again at downstream. once a baffle works as a door shut off one side path, diverge happens. mesh quality is not good but works well as i mentioned in first post.
Old   November 10, 2003, 04:51
Brian
If your baffle door shuts off a side path, and the fluid in that path becomes completely separated from the rest of the flow, it becomes a two-stream problem. In other words, you have two completely separate flow domains. This is numerically unstable, and requires some special treatment.
See Tutorial 13 for how to handle that - Tut 13 is a moving mesh case, but you should get the idea.
baffle and wall BC in v4.06 solarwind Siemens 0 January 16, 2009 03:43
HELP: baffle generation sunlight Siemens 3 July 29, 2005 03:07
baffle boundary sankar Siemens 3 March 16, 2005 03:54
Baffle problem.. mohr76 Siemens 0 July 14, 2004 07:37
porosity of baffle raymond Siemens 4 April 4, 2002 04:03
